Steering wheel vibration
Old 07-07-2017, 06:31 PM
ChryC6's Avatar
Steering wheel vibrates at idle when AC compressor kicks in. Smooths out under acceleration. No change in cooling either way.
Old 07-13-2017, 10:24 AM
TexasHonda's Avatar
If idle speed is dipping below 600 rpm, suspect a very dirty throttle plate/body. Clean carefully using throttle pedal w/ key on to open throttle plate (don't force open). Idle should be around 700-800 rpm.
If no improvement inspect motor mounts for problems.
good luck
csmeance
1/2G MDX (2001-2013)
63
10-06-2018 05:13 PM
mike0mike
15
10-10-2016 05:21 PM
rets
01-01-2013 09:50 PM
Bliyun
05-21-2012 11:23 PM
Quick Reply: Steering wheel vibration
