i am looking for a diagram of the fuse system for my 06 tsx. i need to know what accessories run off of the 40 amp back up fuse under the hood.
i never thought of that. where can i get something like that? i really jus want to know what accessories run off of that 40 amp back up,acc fuse.
JDM Addict
well, helms makes the manuals for our car.
so helminc.com is where you would go to buy one.
it has all of the wiring diagrams and schematics and all of that stuff.
mine says the following:
fuse no. 15 / BACK UP, ACC / amps: 40A / Protects: Fuse 7 in under-hood fuse/relay box,
Fuses 5,6,7,8 and 9 in under-dash fuse/relay box
so I guess it protects other fuses?
and more detail:
Fuse 7 under-hood is: BACK UP / 7.5A amps / Relay control module
Fuse 5 under-dash is: Dashboard wire harness (left branch)
Fuse 6 under-dash is: Dashboard wire harness (left branch)
Fuse 7 under-dash is: Option connector
Fuse 8 under-dash is: Floor wire harness (left branch)
Fuse 9 under-dash is: Floor wire harness (left branch)
and more detail:
JDM Addict
scratch that last part there.
I quoted the 5-9 under-dash wrong.
the correct info is as follows:
Under-Dash Fuse:
5: AUDIO AMP: 20A / Stereo Amplifier
6: INTR LIGHT: 10A / Ambient light, Audio unit, Ceiling light, Driver's vanity mirror light,
Driver's door courtesy light, Front passenger's vanity mirror light, Front passanger's door
courtesy light, HandsFreeLink control unit, Individual map lights, Trunk light
7: BACK UP: 10A / Combination switch control unit, Driving position memory switch,
Gauge control module, Immobilizer control unit-receiver, Imoes unit ('07-'08), MICU,
Navigation display unit (Navigation), Navigation unit (Navigation), Power seat control unit,
Power window master switch, Wiper/washer switch
8: DOOR LOCK: 20A / MICU
9: FR ACC SOCKET: 15A / Accessory power socket relay
Under-Dash Fuse:
I have a 2006 TL and my battery continues to die on me. Dealership says battery is good and a draw of 0.23 - 0.61amps (fluctuating ) is normal. THEN WHY? Any ideas
Summer is Coming
Rocket_man
Summer is Coming
close
- Join DateJun 2005
- LocationHouston
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:647 Times in 373 Posts
Quote:
Over half an amp of draw when the car is off??? Wow that sounds like a lot to me.Originally Posted by Steve_vriens
I assume they checked the alternator.
Take the car to Autozone and ask them to connect thier battery tester. You can watch the results for yourself. There is no charge for that.
If that shows good then you may have a difficult problem finding the problem. Could be a door switch. I had a buddy who had a bad starter that drained the battery (not an Acura) and that was pretty hard to find.
The amps fluctuated to .61amps for approx. 4 sec's then back down to .23amps. The Mechanic at Acura didn't even flinch, as if it was normal or he seen it before and has no idea what it could be. I told him that I pulled fuse #6 and #7 . One stopped the fluctuation and the other reduced the amps by .28amps. He didn't seem to care and scratched his head....hmmph
What fuse would I have to pull to stop the radio buttons or the radio itself from working?
The lights on my radio don't turn off when the car is off and they are drawing power constantly which ends up killing my battery.
justnspace
close
- Join DateFeb 2010
iTrader Positive Feedback100
iTrader Feedback Score(1)
Liked:16,291 Times in 11,991 Posts
Quote:
On the TL side, we have lots of threads concerning this.Originally Posted by Steve_vriens
your HFL is the culprit.
disconnect it, and or replace it.
3rd Gear
I have the same problem. Did you get it fixed? If so, what was the issue?
