Fog light mod for 06 tsx
Old Feb 17, 2006 | 09:03 AM
dwest1023's Avatar
I was wondering if any one has thought about moding the fog lights to turn on, with the parking lights. There is no service manual available yet, so I have no idea which wire is used to make the fog light switch hot. Seems to me that all I would have to do is locate this wire and connect it to the hot parking light wire.
Anyone?
Old Feb 17, 2006 | 09:07 AM
moda_way's Avatar
Anyone?
It has been talked about for the 04-05 fogs (seemingly no different). Was not a successful pursuit.
Old Apr 17, 2006 | 10:42 AM
STL's Avatar
STL
That is a big bummer. Any idea why it couldn't be done? The only reason I can see that would make it too difficult is if all the needed connections are in the lighting stalk itself.
Old Apr 17, 2006 | 07:26 PM
moda_way's Avatar
That and everything is wired from the Relay directly into the fuse box. Kinda hard to beat that.
Old Apr 17, 2006 | 07:49 PM
subdued's Avatar
my acura sanctuary
Hmm?? sounds like a number of obstacles are present to make this not that easy.
So I wonder.....would it be possible to disconnect the OEM fogs from the stalk control and add an aftermarket aux light rocker type switch and/or wire it to come on with the ignition? Basically bypass the stock controls and wire it as though it were aftermarket.
So then the Fogs would be Auto-On with ignition and then the front side markers would have to be turned on with the light stalk (as normally done). It is not an all-in-one as the OP desired but a potential work around. Maybe?
***BTW I want OEM fogs as DRLs***
Old Apr 19, 2006 | 12:57 PM
subdued's Avatar
my acura sanctuary
It seems that so many Canadians who have DRLs don't want em, and others in US who 'hate' DRLs maybe just want to be stealth and not attract attention for ??? activities they may be involved in (0-60 runs?)
I still want them on my 06. And prefer not running the HIDs. So the search continues. Any help how to get DRLs using fogs would be appreciated. thanks, ed
Old Apr 19, 2006 | 02:09 PM
kvanpelt's Avatar
6th Gear
Here is a quote from the VA law:
B. Not more than four lights used to provide general illumination ahead of the vehicle, including at least two headlights and any other combination of fog lights or other auxiliary lights approved by the Superintendent, shall be lighted at any time. Fog lights shall be lighted only in fog or other inclement weather.
I'm sure it is also illegal in other states as well. Fog lights are very bright and pointed in a direction to aid visibility in fog. When used when there is no fog they are too bright and can blind oncoming drivers. It is because some people leave them on all the time that laws are being passed to prevent it.
Old Apr 19, 2006 | 02:58 PM
acn684's Avatar
fog lights are usually aimed low arent they?
Old Apr 19, 2006 | 03:52 PM
kvanpelt's Avatar
6th Gear
located low - not necessarily pointed low and they have a different spread than headlights.
have you noticed that they go out when you put on the high beams? only two lights (high candle power) per side are legal.
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
ellisd03tls
Sep 8, 2015 04:17 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
