Drive Belt Adjusments
Acura TSX 2004 5AT
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
Owners manual says to check the drive belt tension by looking at the arrow and checking if it's in range.
Mine seems to be in range but at the very end of the tolerance limit. Do I need to get the belts adjusted before it becomes very bad? or is it usual for the arrow to be at the end of the tolerance limit?
Because Of You
Check the service manual. The "range" in the service manual is different from the "range" in the owner manual by some unknown reason.... The one in the service manual points it to the end of the "second" rectangle. The one in the owner manual points it to the middle of the 2 rectangle.
Acura TSX 2004 5AT
I don't have the service manual to check this.
Looking at the '15 TLX
Originally Posted by Deepfreezed
yes, mine is pointing to the end of the rectangle. end towards the front of the car.
The standard range for the belt is anywhere from the beginning of the longer rectangle (towards the front it looks like from the diagram) to the end of the shorter square (farthest away from the front).
So it sounds like yours is in range - barely.
PS - My service manual shows the triangle pointing between the longer rectangle and smaller square but again, I base my statements on the '04 shop manual.
Scan of page 4-29
Originally Posted by Stevestr
According to the '04 TSX Service Manual p 4-29:
http://www.stevestr.org/images/acura...lt_Inspect.pdf
Acura TSX 2004 5AT
Here's the scan showing the range. See step #2 for the interpretation.
mine arrow is point at the same spot as the service menu, and belt is making a noise. there is no crack no break on the belt. i am wonder if the tensioner or belt is at fault on my 04 TSX, 50,000km
asahrts
09-04-2015 05:55 PM
