Drilling out a screw
boost owns
In April, I swapped an 06 OEM steering wheel into my 04 TSX. This went well, except that I didn't properly re-align the cable reel before mounting the new wheel. As such, my wheel is between 12 and 1 o'clock when the car's tracking straight ahead.
I tried to remove the steering wheel to correct the problem. However, in doing so, I managed to strip the T30 bolt on the left side of the wheel holding the airbag in. It won't budge. I tried an adhesive product called ScrewGrab, but that didn't help at all. The bolt's totally stripped and won't move.
At this point my only option is to drill that bolt out. I've never done that before. Does anybody have any advice for me? What kind of bit should I use?
Clearly, the battery would be disconnected, as would the airbag, before attempting this.
Any help's appreciated. It's more maddening each day to drive this car with a slightly crooked steering wheel!![Tomato](https://acurazine.com/forums/images/smilies/tomato.gif)
- Matt
- Matt
JDM Addict
bolt huh?
http://www.amazon.com/Gator-Grip-ETC.../dp/B000065CJ8
or
http://www.asseenontvguys.com/index....ROD&ProdID=380
should probably be used first by someone not used to what you
want to do.
it's better to try these then to try to drill out the bolt, put a new bolt in,
drill that out, tap that, blah, blah.
or
want to do.
boost owns
Its OK to do that? I was worried that correcting a poorly-installed steering wheel by changing the alignment might have negative affects on the overall handling of the car... if it's a viable solution then sign me up, that's exactly what I'm going to do!
boost owns
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
