Creaks, rattles and HFL issue
Have a 07 auto TSX. The following issues have popped up lately-
1. Creaking from steering column. Happens when I am driving on rough, bumpy uneven roads at low speeds.
2. rattle from glovebox. Cabin air filter was changed recently by a auto shop. Rattle appeared after that. Goes away if I open the glove box while driving. Could they have broken something in there?
3. Finally, is there a way to set the HFL to unlock mode without having to put in the code everytime I start the car. Initially it was set up like that but then my battery drained on me and I had to get a jump. Ever since, the HFL locks out when I shut the car and needs the code to unlock on starting up.
Thanks!
Thanks!
Not sure if your problem #1 is this or not, as the TSB states the steering wheel squeaks when turned, and yours is when you go over bumps, but:
https://acurazine.com/forums/1g-tsx-2004-2008-124/power-steering-rack-squeaks-tsb-10-025-a-789133/
marcelft
07-10-2018 06:17 PM
CheeseyPoofs McNut
10-11-2015 11:25 AM
jaynatlanta
5G TLX Problems & Fixes
09-15-2015 11:08 AM
