could my windshield be lose?
#161
Go Giants
Back from vacation, I will bring it in this week...
#162
I dont even want to say this b/c with my luck the noise will re-appear... But i went to the dealer to have my untollerable window/door seal squeaks handled even though I didnt want the dealer messing with the car. btw, they lubed the crap out of my door seals and NO MORE NOISES (3 months now). again, knock on wood... It was annoying to not be able to touch the door frame for fear of getting a lube job on your hand or arm, but oh well... I also didnt open my windows for 2 months out of fear that it would dry out and come back, but thankfully its still good.
I had asked the guy about the windshield noise on the phone prior to setting up the appointment. I only heard the crackling noises a handful of times and Ive had the car since February. I told him I dont want anything done unless there is some sort of documented solution, as i dont want my car being the guinea pig and have other rattles produced. He said he thinks he knows the problem as there was a bulletin out for the windshield cowl. when i picked up the car they had lubed the seals (obviously bc they also got it on my seats), but no indication on anything that they did the windshield. the guy had mentioned that he 'took care of it' & 'readjusted some parts', which we all know basically means they looked, saw no noises, and decide to pacify us... But, I have not heard the windshielf noise since... KNOCK ON WOOD.
hmmm, i dont know how this answers any questions, but maybe it helps someone be assured that it might just be attributed to readjusting something with the cowl?
My only noise, (again knocking on wood), is the damned to hell steering wheel rattle. it doesnt make it much, but its still annoying and sounds like loose screws floating around. Anyone have a fix yet?
#163
I have the same tick/rattle/tapping noise from the base of the windshield on the passenger side. I bought mine in mid September ( i think the build date was in JULY). I have not tried the fix by 03jeff, but i'm going to try it at some point.
I noticed that the tapping noise is also related to tempurature/weather conditions. This morning it was super cold (20 degrees F - 30 degrees F) and there was no tapping. But during the weekend on Saturday, it was tapping like crazy over bumpy roads and it was warmer in the 50s. If it is over 60 degrees there is no tapping. This is an odd problem and it seems people are getting it fixed in different ways. I hope the shim solution works b/c i'd rather not have a dealer tearing the windshield off, only to have it continue to tap a week later.
My wifes Jeep liberty ( A CHRYSLER PRODUCT) is exactly one year old and has 15,000 miles on it. ZERO taps/rattles etc. now why does my acura have this stupid problem. I bought this car so it wouldn't have these issues!!
I'll post in here if the shim fix works or does not work. But i'll give it a week or so to see for sure that it works for me.
#164
Bye TSX, hello domestic?
#165
I'm the Firestarter
My windshield rattle/squeek was there for two days but I haven't heard it since. I booked a service for next week but now I wonder if I should even bother going, if they can't hear it how can they know they fixed it??
#166
Go Giants
#167
Originally Posted by ZmanTSX
I have same rattle issue...
The dealer said it was fixed with some adjustment to the glove box...BS, the noise is still there. Funny thing is, it was raining when I picked it up and the noise was not there.
Same conditions for the same windshield noise...dry colder air..mine starts around 60 degrees.
I am in NJ ans saw a post that Denville Acura fixed it with some moulding adjustments. Did this work, now that it is cold out??? Do you have a contact name there?
thks
thks
#168
6th Gear
I'm so happy to see that I'm not the only one with this problem. Whenever it gets below 70 degrees outside it sounds like the winshield is going to fall out of my car every time I go over a bump. The best way I can describe the noise is like cracking glass. It actually sounds like I am stepping on a piece of glass and slowly breaking it. The noise seems to come from the lower passenger side of my windshield and from at the top near the sunglass holder.
I have an appointment scheduled for next week for my 3500 mile oil change so I am going to have them look at it then. It makes me a little nervous since there does not seem to be a common fix for it yet.
I haven't seen any St. Louis posts on this yet so I'll let you know what the local dealers fix is. I just hope it is not raining when I bring it in.
#169
Go Giants
Big Update!!!
Went straight to the dealer this morning (Precision Acura, Princeton NJ) and the service manager told me some good news. He said Acura now recognizes the issue and is developing new moldings . The SM tried to order them, but Acura won't give them to him yet, he thinks 3 weeks or so. He said since I came last many others have complained (I was the first), due to the cold. He also said that he has heard all other fixes (the wedge by the firewall, replaced molding, etc.) were all temporary fixes and that this would be the definitive fix from Acura.
Fingers crossed, will let you know....
#171
Go Giants
Originally Posted by jiggaman
i get a creaking sound from the rear glass, anyone get this too?
#172
#173
I spend 2 much time here
Originally Posted by xizor
that's the only one I have now. But from what I can tell its not related to cold, because I have it all the time, but it doesn't creak on every bump. It kinda of comes and goes randomly, its not as annoying or persistant as the front winshield one.
#174
Mine is going in for the crackling winshield next week, I tried stuffing some cardboard between the headliner and windshield (under the rubber strip) right around the rearview mirror assembly and the noise subsided a bit.
I also have a buzzing noise coming from the rear deck that seems to occur when I bear right or left (for example when taking an exit ramp). Anyone else experience this?
#176
Go Giants
Originally Posted by Wtbs2k
Hey guys , i found another way to fix the noise. I put a little washer between the 2 rubbers at bottom of the windshield on passenger side. No clicking sound for about 1 1/2 weeks now.
#177
She said: it's GINORMOUS!
#178
Originally Posted by mg7726
did you put it on the outside, next to where the wiper is? or a location under the hood?
#180
ok guys, i also have this problem. Just making sure that we are talking about the SAME thing here: mine also sounds like its coming from the front passenger dashboard area. But my passenger says that he hears it from the driver side. So i suspect it is coming from the entire dashboard. It just sounds like its coming from the passenger's side when I'm driving because of where i sit. It is NOT A GRINDING noise, NOT A CREAKING noise, not a RUBBING noise. It definetily sounds like a clicking sound whenever i hit a pothole. I took it to the dealer yesterday but couldn't replicate the noise. I even test drove with them and the noise didn't show up. I really think cars know when they are being test driven. But the dealer said they put sdome kind of insulation there. i don't know. I just know i will hear it again. and i will be back at the dealer again.
#181
I have the same issue. I seem to hear it coming from the rearview mirror assembly, and examined the area. On mine, the rubber strip that connects the headliner and the windshield seems to have a bit of a gap. I wedged some cardboard (actually a folded up gum package) in between and the clicking seemed to go away. It also fell out after a couple of bumps, so I think it may be part of the problem. Placing the washers at the bottom may be pushing the windshield up and creating a tighter seal at the top.
#182
Go Giants
You should try to stick a washer in there too. it wouldn't hurt to do that
Tried that, same noise. Yours will come back, sorry.
#183
Go Giants
Sounds like a different noise. The noise I think we are are talking about sounds like hail hitting the windshield whenever the car moves horizontally. Almost like if Superman was pressing against your windshield from the outside. Others have said it is not too loud, but mine is very loud.
#184
For some of you here who think its coming from the top part of the windshield or the rearview mirror, check your moonroof. It may be coming from there. Coz mine was rattling too when its closed and the shade is open. And it does sound like rain is coming down to it. So maybe thats waht your'e hearing. The moonroof is just a bit loose. Just a suggestion.
#185
#186
Go Giants
The Moonroof shade rattle is another issue. Acura has a fix for it and fixed mine (I have almost every rattle so far).
#187
sue the f*** out of me for even opening my mouth a few posts earlier. Today, after more then 3 months of a quiet windshield, it was crackling and rattling ALL DAY LONG. and its not even cold out!
#188
Go Giants
#189
Old fart
#190
Go Giants
Originally Posted by TSX 'R' US
Acura has a fix for that?? And my dealership doesn't know about it??!!??
#191
Had the car in the dealer this week for the windshield noise. They replaced the windshield, and some molding and the invoice said they also fixed some plastic welds that broke.
It hasn't been cold here since I picked it up so I can't tell if it is fixed, I will keep you posted.
#192
Originally Posted by michaelbolton
Yeah I had Denville Acura fix it, and now that it's cold, still no rattle so far. Unfortunately I don't have a contact name for anyone in the service department.
Thanks for the assist. I will call them.
#193
#194
Go Giants
#195
So I am assuming your other fix wore off?
#197
Go Giants
Originally Posted by jojo77
Just want everyone to know I get the same rattles on dashboard and I got a 2005. Will be calling dealer soon to fix this.
#198
and i got a wood-trim PWP non-navi TSX loaner i missed the navi on that
#199
ok, i just got my car back from dealership from clicking noise on dashboard area. We couldn't replicate the noise but they went ahead and put insulation around it. The clicking noise did go away for a couple of days but its slowly coming back. I knew that the insulation wasn't the problem but they couldn't do anything since the clicking noise didn't showe up during test drive. I know something is loose down there and I'll hear it again and off to the dealer i go again...
#200
Took my TSX in (1,400 mil) to get my tags and have my windshield creak fixed.
Guys at Chevy Chase Acura in Maryland said they'd had a bunch of requests for the exact same fix, and that Acura had issued service instructions for it. They replaced molding and added insulation around the windshield/dash area under the hood, rattle is totally gone.
Moves my satisfaction level from 9.0/10 to 9.5/10. If my tweaters weren't buzzing every now and then, it'd be perfect
