Clear Bra for fog lights...uh oh!!
#42
Haven't tried to remove the old ones yet. Still thinking of a way to install some kind of screen over the lights or maybe drilling small holes on top and bottom of the foglight housing for ventilation/cooling. I have two cracked lights I replaced to use as test subjects.
When I do try and remove the Xpel covers I'll start with a hair dryer or heating gun (paint remover), scrapping razor, and the water/alcohol mixture (same used when installing). Whatever I do will involve removing the light first.
#45
Originally Posted by dzuy
what's with all these old thread being resurrected?
#47
I cut a piece of gutter guard to fit the frame
Four black cable ties are insted into the frame
Attach screen using cable ties
Finished frame
Foglight with burnt protector
Remove frame from foglight
Reinstalled foglight and finished frame
Front View (lights off)
Front View (lights on)
If you try this just be carefull because the screen's cut edges are very sharp. As you can see I also installed the screen in the upper and lower grill openings.
#48
Nice work!!! that looks really good. I am not getting fog lights on my car, but i do like the look of the screeen behind the upper and lower openings. Where did you get the screen and how much did it cost??
#50
#51
Originally Posted by mg7726
nshom, nice work!!
but make sure the tie wraps don't melt b/c that will scratch the fogs. i like the engine bay mods
#56
My Home Depot (Houston) had two types, Galvanized Steel or Aluminum. They were selling the Gal/Steel ones separately for $1.40
I assume you were using the steel product?
Home Depot for around $6 (US). The package contained 4 or 5 pieces (not sure) of which I used 2.
#57
Yes and it came with 4 pieces. I used two pieces for the entire front end. Just be careful the edges are very sharp. I have the cuts to prove it.
#58
#59
I'm thinking about putting a convex shape on the metal fabric prior to mounting, by putting in a large bowl of some kind and rolling/pressing it with some kind of rubber/leather mallet or something, anything to get a little more clearance between the metal fabric and the front of the foglight lens. Do you think it's necessary?
#61
nshom, how hard it is to install the mesh behind the grille? Wondering if it less involved than the fog lights?
#62
The front bumper cover has to be removed just like the installing the foglights. The mesh has to be cut to size and shape using a pair of sheet metal shears. Holes have to be drilled in the appropriate places. Mesh is attached using cable ties. Bumper cover reinstalled. It took me about 2 1/2 - 3 hours which included the foglight screens.
Thakns for the info... i will have to look into this. I love the look of that mesh!!
#63
Modified foglamp protection
Also, here is a pic of just the wire mesh after it was formed.
#65
Originally Posted by TSX 'R' US
I wonder how hot that wire mesh is gonna be...and if it'll melt your zipties... Have you tried them on yet?
#66
Ran it for an hour this morning, however, it was cool (32F) this morning.. They are about 1/8 away, and the grill is only warm to touch. If the cableties are a problem, I will use stainless steel wire instead.
#68
I finally went to a honda dealer and bought the fog kit for the Honda Accord. They gave it to me at the same price I would have paid if I had ordered just the two replacement fog light assemblies! Anyways...I tried to take my fogs out today but it looks like I have to remove the bumper to get to them. How do you guys take them out? It's like 20 degrees out there and so I decided to quit for another day.
#69
https://acurazine.com/forums/showpos...8&postcount=12
#70
Thanks Viking but I already have that instruction manual. The bottom screw is easy to get at but the one on the side......I can't see where the screw is! It looks so easy but when it's -6 C outside, it's a whole new story.
#71
I also have the same problem with mine. I purchased them from WeatherTech.com and they said they would get back to me after they speak to XPEL who manufactures them. They also asked if I use high intensity bulbs instead of the normal bulbs and I told them normal. What type of bulbs are you guys using who have this problem?
http://weathertech.com/store/vehsear...pt_choice_id=0
Just the films for the head lights and fog light?
#72
PVC vs. urethane
the 40 mil protection they are selling is not a urethane like they say (i am pretty sure). urethane comes only up to 18 mil and will withstand more heat then the 40 mil PVC.
i think that is the problem you are referring to. some of the lights generate too much heat for the PVC to handle it. the urethane film would be fine and will give you the same protection than thicker PVC.
if you need the light kits let me know, i can help.
good luck
good luck
#73
good luck
good luck
#74
Did it require removing the front bumper to place the mesh in the foglight area? I just purchased my car and am not fond of removing the bumper myself. If it's possible, yet more difficult, to do with everything intact, i would rather do it that way.
#75
don't think so....cause you can remove the foglight housing by removing 2 screws from each foglight. 1 of the screws is on the bottom, and the 2nd is on the side that's closer to the center of the car. you'll need a long magnetic phillips. you can remove the screws w/o using a magnetic screw driver, but putting them back in will be PITA.
#76
Oh man....just spent, literally, 6 hours changing 1 fog light!! omfg...i'm such a
Took the entire bumper off...removed the fog light housing...replaced the old with the new (old got shattered by a rock on the highway ) ...assembled back in 1 piece with only 1 clip that i have no clue where it goes. Haha! Not too worried about it b/c I know it's a clip that doesn't play a critical role in the secured assembly of the bumper...
Anywho...what a learning experience. I think i'll give it another whirl tomorrow!
Tomorrow I'm getting the clear bra and clear headlight/fog light film installed. Bought the film from RockBlocker...hopefully it won't brown on me. If it does...i may have to take it all back off and do the mesh grille. I really like that
#77
NSHOM - how about those cable ties?
Nshom,
It seems you have had the grille/mesh installed for over a year now with the cable ties. Can you give us an update about how they are holding on...I guess they are good enough and did not melt. So, no need to use the metal wire instead?
Separately, any idea where i could get the black screen/mesh instead of the metal/silver looking one?
#78
I know, "Holy thread revival," but I just gotta ask: Is it possible to mesh the same way in an 06? I haven't heard of many 06 people who took out their foglights since it's integrated anyways. Any ideas? Don't wanna take off the whole bumper
#79
Originally Posted by nevaspb
Nshom,
The mesh is holding up fine with the plastic cable ties however I suggest painting the mesh silver before putting them on. The unpainted gutter mesh darkened over time. I plan on reinstalling the mesh but painting it first.
As for the black mesh I installed it on my 2005 Honda Odyssey to protect the radiator. The mesh is plastic and sold in rolls at Home Depot for less than $10. It's not as stiff as the metal mesh and since the mesh is very close to the lens (on the TSX) it may not protect the lens from debris as well as the metal mesh.
#80
