Changing spark plugs
Old Nov 2, 2008 | 04:57 PM
Easy one 7's Avatar
4th Gear
Question Changing spark plugs
What is the best type of spark plugs for a 2005 tsx,and what tools are require to do the job seeing has the spark plugs are on top but down deep.
Old Nov 2, 2008 | 05:32 PM
aaronng's Avatar
Driver/Detailer
The best type is the stock sparkplug because it is an iridium tipped sparkplug, which lasts longer than both the copper and platinum type plugs. The downside is the price.
Old Nov 5, 2008 | 09:17 AM
litesout's Avatar
Oliver!!!
Agreed. What kind of mileage do you have on your car? The factory irridium plugs should be good for at least 100k miles (I think they recommend 110k, but don't quote me on that.)
As far as the tools, a standard spark plug socket and a long extension should be all you need to remove them. When you go to put them back in, I've found its easier to remove the little rubber boot from the socket, that way it doesn't come off the extension after you're done putting the plug in. And don't just drop the plug down the hole. You could ruin the gap that way. Instead use some kind of grabber, like one of those claw looking things. The ones with the three little claws that come out when you push the button on the top.
Old Nov 5, 2008 | 01:23 PM
78transam's Avatar
2005 TSX 6MT
One of the "tools" I've used for spark plug installation on OHC motors is a short piece of rubber hose. I push it over the end of the plug, place the plug down in the well, and screw in the plug. Remove the hose and torque the plug to spec. I've also used the same hose to fish a loose plug out of the well. Don't forget to use anti-seize on the plug threads.
Old Nov 7, 2008 | 07:26 AM
adc's Avatar
adc
This should help:
https://acurazine.com/forums/showthr...ighlight=spark
pstomps
Feb 20, 2017 03:29 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
Sep 17, 2015 10:16 AM
Aleax
Sep 11, 2015 11:31 AM
NSolace
Sep 3, 2015 08:14 PM
