Changing battery - what gets wiped from mem?
I know that the dealership has a memory saver (back up battery they use while swapping). Just wondering what I will have to re-enter. Possibly stereo code (will have to dig for that) Maybe all my radio stations.
Any ideas on a replacement battery? Does it even matter?
Originally Posted by fadinglionhart
you won't lose the radio stations, just need to input the navi code (if you have one) and the radio code.
Originally Posted by visuelz
I changed my stock acura battery to an optima redtop but I did not lose anything except i had to reinput my radio code.
just disconnected my battery today cuz i thought it would reset my oil life(changed oil myself)but it didnt and stayed the same..then i had to enter a code for my radio..does anyone know the code or how to reset the oild life?
Try this: (It works for the 05 but that doesn't have the oil life)
Turn off car
Hold Select/Reset
Turn on car to ignition II
Keep holding for like 10 seconds
Also...the radio code should be with the stuff that came with your car. If not check the side of the glove box. If it's not there, check the underside of the fuse box under the hood. If it's not there go to the dealership and ask them to pull it up for you. Some will try to charge you but it should be free according to Owner's link.
Turn off car
Hold Select/Reset
Turn off car
Hold Select/Reset
Turn off car
Hold Select/Reset
thanx man i just did it and it works ok..but does the timer adjust back to itself or do you have to do it? oil lifes still the same might go to the dealer ship to see what i need to do...
mada51589
05-03-2022 08:54 PM
