Catalytic Converter Failure At 43,000 miles?
Old 03-07-2008, 03:28 PM
acuraaddict_RENAMED's Avatar
Question Catalytic Converter Failure At 43,000 miles?
MIL light came on yesterday on my 2004 TSX with 43,000 miles. Today dealer diagnoses that the catalytic converter is failing. Test shows it is operating at only 60% efficiency. Dealer says they have had a few TSX's come in with this problem, not to worry warranty will cover the cost.
Has anyone else seen their cat fail this prematurely? I am concerned about what caused the failure and will the new one fail at the same rate because of some fuel to air mixture problem etc. Car has gotten consistent MPG of mid to high 20's overall.
Seems strange to me and I have searched and not found any posts with a similar story.
Old 03-07-2008, 03:34 PM
PACman's Avatar
Interesting; this would be the 1st I've read our Cat failed under 50K miles. One thing I can think to be a reason would be inappropriate air/fuel mix. If the O2 sensor is damaged, the engine could run rich, and the non combusted gas goes through the Cat, destroying the cells in it. Has your dealer given you an explanation?
jmathew34's Avatar
strange, only things i have heard of were the O2 sensors failing...
Old 03-07-2008, 03:36 PM
jlukja's Avatar
Ask for the 06 cat as a replacement (fewer cells, better flow).
Old 03-07-2008, 09:17 PM
bRunCL's Avatar
just browsing the forums I know on older cars like my cl the warranty on the cat is a federally mandated 8 yrs. 80,000 miles. don't know how it works for the tsx's
Old 03-07-2008, 09:42 PM
still plays with cars
nbtx's Avatar
Has this vehicle used much/any oil so far ? About the only thing that kills 'em is excessive oil burning and the amount of phosphorus in the oil. The 49 states warrantee is 70,000 miles and California is 80,000 miles. Maybe the OEM supplier made some defective product; that's what warantees are for.
Old 03-07-2008, 09:46 PM
I have not gotten an explanation other than that they have had similar cat failures on a few other TSX's. If an oxygen sensor had failed allowing a wrong air/fuel mix it should have thrown a code they would have read shouldn't it?
It has not burned a drop of oil since new. I switched to Mobil 1 at the first oil change. Car has run fine with good gas mileage, no smoke from exhaust etc.
Old 03-08-2008, 07:15 AM
feuss2's Avatar
How was the 60% efficiency determined?
Old 03-08-2008, 12:16 PM
LukeaTron's Avatar
Sometimes parts just fail prematurely. You probably just happened be on the outside edge of the bell curve.
Old 03-15-2008, 08:22 PM
Well, the catalytic converter was replaced yesterday and all seems well. It was not replaced with the converter spec'd for the 2006 TSX. Apparently the new part number for the 2006 does not supersede the old number for the 2004's.
The only code stored was "P0420 Catalyst system below threshold 123505 .6 Inspected Cat can hear loose parts inside".
All was done under warranty and that is a good thing since I understand the part alone sells for about $900.00!!!
Let's hope it doesn't happen again in another 43,000 miles.
Old 03-15-2008, 09:20 PM
Driver/Detailer
aaronng's Avatar
Cats don't cost $900. That's the "dealer" price.
Old 03-15-2008, 10:27 PM
TSXHunter05's Avatar
glad to hear its fixed. I thought I've read or heard somewhere though that Cat covertors don't go bad but are destoryed by something in the engine.
defitnely keep a close eye on this one.
Old 02-28-2009, 08:41 AM
TriniTuner's Avatar
I have the same thing. 2004 TSX with 53k miles. P0420 code popped up and dealer diagnosed the Cat was bad. Hmm.
Old 02-28-2009, 11:25 AM
npolite's Avatar
Yep exactly...I checked and it lists for $737 and can be purchased online for $552
http://www.acuraautomotiveparts.org/...s=&view=normal
It's still not a fun job to do especially if you have to grind off the rusted bolts.
Old 02-28-2009, 11:54 AM
atltsx's Avatar
No misfires?
Old 03-01-2009, 07:24 AM
nbtx's Avatar
Your vehicle is still under the emissions warrantee - did the dealer agree to fix it?
Old 03-01-2009, 09:05 AM
TriniTuner's Avatar
Yeah, dealer is going to fix it under warranty. The emissions they said are covered 8 yrs/ 80k miles. I'm just concerned about it happening again in 50k more miles.
Old 03-01-2009, 01:42 PM
nbtx's Avatar
Catalytic converter failures are pretty rare; you should be good to go for the next 100k miles unless you are dumping weird additives in the oil and/or fuel tank. Stick with quality oils and toptier.com fuels.
Old 03-01-2009, 02:14 PM
moda_way's Avatar
Yes, my cat "failed" on my 2004 TSX. Coincidentally it happed the same time Random Technology came out with their cat. lol
Old 03-01-2009, 02:49 PM
Unregistered User
valeratj's Avatar
haha lucky u .
It is strange that cat failed so relatively early. What could cause this? Fuel additives? salty roads? I heard alcohol based additives ruin cat.
Old 03-01-2009, 09:33 PM
TriniTuner's Avatar
I have a feeling that the fact that my TSX does burn some oil might affect the life of the cat. It doesnt burn that much, maybe 1/2-1 quart every 3 or 4k miles.
Old 03-02-2009, 05:24 AM
moda_way's Avatar
That and it not getting hot enough (i.e. short trips) to get into a self-cleaning temp don't help either.
Old 03-02-2009, 09:47 PM
nbtx's Avatar
That's not enough oil burning to affect the cat life much. Especially since there is less zinc and phosphorus additives in current oil. SM-rated oil has the lowest ZN and P.
Old 03-02-2009, 11:08 PM
TriniTuner's Avatar
Dealer also said that they spark plugs were pretty dirty and this might contribute to the issue? Anyways, going to change plugs. Anyone have good recommendations for a spark plug?
Old 03-03-2009, 10:37 AM
nbtx's Avatar
Bigger concern - what gasoline are you using?
Old 03-03-2009, 07:29 PM
TriniTuner's Avatar
Usually Exxon or Shell Premium 93 Octane.
Old 03-03-2009, 10:01 PM
nbtx's Avatar
Good fuel and minimal oil consumption - it sounds like things are going fine.
I would expect the plugs to be clean and good for another 50 K miles.
If you are going to replace them, use the OEM parts instead of experimenting with other manufacturers which might not have compatible heat ranges.
Old 03-02-2010, 12:08 AM
Question
I started this thread in March of 2008. My converter was replaced at 43,000 miles after throwing a P0420 code. The new converter has now failed after only 11,000 miles...same code. Dealer says Acura has determined that some 2004's had incorrect programming and was causing the engine to run lean and producing exhaust temperatures to run high enough to melt the insides of the converter. Solution is a software patch and another new converter under warranty. How does one converter last 40,000 miles and the next only 11,000 miles if the problem originated at the factory?
It seems to me there is a problem that is getting worse. Any other ideas?
Old 03-02-2010, 07:51 AM
Someone stole "My Garage"
curls's Avatar
Wow, 11,000 miles on a new cat? That's insanely low -- thank goodness you weren't footing the bill for it!
I don't think you have much reason to believe otherwise. I think they are being straightforward with you and telling you the truth, although I've never heard of this software glitch before. But, if they are adamant that this is what it is, I'd approach them and ask for an extended warranty on the newest catalytic converter now (most warranty-installed parts are only warrantied for 12,000 miles / 1 year or something like that). Get it in writing and hope you never have to use the paper they sign.
Old 03-02-2010, 05:26 PM
in the 24th and a half...
DuckDodgers's Avatar
On the other hand, the Federally manadated emission system warranty WILL remain in effect on a replacement part...they CANNOT circumvent this mandate with the old 12,000 mile/12 month replacement part dance.
Old 03-02-2010, 05:30 PM
Miamicarfan's Avatar
Guys:
I am past my warranty. The emissions parts warranty extends longer than the regular warranty right? The regular warranty on engine and transmission is 4 years or 50,000 miles. What is the warranty on exhaust parts? Is it 7 years or 70,000 or 8 years and 80,000 miles? Is this a parts and labor warranty?
Curls:
I know you are in Canada. Are things different over there than in US in terms of the warranty for the emissions components?
Old 03-02-2010, 07:27 PM
curls's Avatar
I'm pretty sure the warranties are the same length, but converted (roughly) for the miles vs km's difference. I don't know for sure but I believe emissions are 6 or 8 years. This does NOT include the exhaust system, but does include a few sensors and the catalytic converter. Does NOT include the O2 or A/F sensors though (I know... my A/F sensor went out a few years ago to the tune of $220 non-warranty dollars. Ouch).
Old 03-02-2010, 08:35 PM
Chelsea John's Avatar
Cat is 8yrs/130Kms in Canada.
Same for the ECM.
Old 03-03-2010, 03:33 PM
CarbonGray Earl's Avatar
I might get a hiflow cat to save my other cat for awhile. My integra cat went out at about 120k miles.
Old 03-03-2010, 07:08 PM
Don't forget '06 on Acuras have 6 yr/70k miles coverage on driveline too (in the US).
Old 03-04-2010, 12:16 AM
Damn. Did they have to wait until 2006 to change this
All Acuras, 2006 and newer have this different, longer and better 6yr/70K warranty?
Although, I am not worried much. My car will sail thru 70k in less than a year.
Old 03-04-2010, 12:25 AM
Same for the ECM.
Guys, some questions:
1) Isn't the ECM the main computer in the car that sits either underneath or very close to the glove compartment box?
Good to know that this ECM has added warranty
2) Has anybody heard of any TSX ECM computers going bad on this forum? I can only remember one situation of a member with a bad ECM. It happened when his heater core started leaking and the ECM got drenched. Other than that, it looks like it is solid.
Old 03-04-2010, 04:21 PM
PACman's Avatar
Yea, I remember reading that thread too. His user name was Frank or something like that. After that unfortunate event, he never came back, stating it would be the last time he'd own an Acura; and I'd assume a Honda.
Other than that guy, I haven't read of anyone else having a ECM problem.
Old 04-20-2010, 11:49 PM
Well, 391 miles after the second cat was installed the #2 O2 sensor has failed. Are there any techs out there who may have seen a service bulletin on this problem?
Old 04-21-2010, 07:20 AM
LuvMyTSX's Avatar
391 miles?? Damn.
I hope you can find a permanent resolution to the problem.
Quick Reply: Catalytic Converter Failure At 43,000 miles?
