I broke manifold connector (see pictures), do I need to replace entire upper manifold
Old 09-01-2015, 07:14 PM
8th Gear
cak165's Avatar
Or is there a way to just replace the connector, it seems stuck in place? Anyone know what they call that connector?
Front hose to upper manifold
Connector was loose
Finally snapped off
Old 09-01-2015, 09:05 PM
tsxykid105's Avatar
you could try to fasten it back in somehow. you could find a used intake manifold or buy a new one. its about $200 oem. also these intake manifolds are 2 pieces. which make it a little easier depending on what you consider easier. i can take one off in 5 minutes if needed.
here is a website the shows the intake manifold. it doesnt look like that piece is sold by its self.
2004 Acura TSX SEDAN|
Old 09-02-2015, 09:21 AM
TexasHonda's Avatar
It's likely either pressed in or brazed. Either way, to replace would require removal of IM, take to machine shop to drill out, and replace fitting (if you can find exact replacement!).
Almost certainlly cheaper to replace entire intake manifold w/ used part. Check ebay for numerous listings. I saw one for $75 incl. shipping.
You may be able to find local to you using car-part.com to source a donor vehicle and calling to confirm availability.
good luck
Ol'Dave
09-05-2020 02:56 PM
cycdaniel
12-17-2019 10:58 AM
james357
02-13-2016 02:37 PM
C2CuSn07 TL
09-11-2015 06:54 PM
Quick Reply: I broke manifold connector (see pictures), do I need to replace entire upper manifold
