Having trouble starting my TSX (see video) after manifold replacement
Old 09-13-2015, 02:08 PM
8th Gear
cak165's Avatar
So I had to replace my upper manifold. I started the car and it was idling a bit high, so I thought I had I should do the relearn process. After I ran it to 3000 rpm for like 10-20 seconds, it shut off and now it's giving me these clicking sounds where the D and P are flashing. See here:
I hooked up an OBD code reader and it wasn't able to read anything, kept giving me error. Don't know where to start looking or diagnosing what the problem could be now? Any help would be much appreciated, it's my daily driver.
Old 09-13-2015, 10:53 PM
Tangoman's Avatar
By upper manifold you mean the intake manifold? Vacuum leak issue?
Old 09-14-2015, 12:16 AM
8th Gear
cak165's Avatar
Yes, intake manifold. The car started and ran for few minutes and then the above happened, would a vacuum leak cause everything to go haywire like that?
Old 09-14-2015, 12:39 AM
P1zzaman's Avatar
Hmm probably different than my problem?
My issue was the battery.
Old 09-15-2015, 10:48 AM
TexasHonda's Avatar
Check your battery connections. Check grounds you may have released/damaged during intake manifold removal.
good luck
Old 09-16-2015, 08:17 PM
8th Gear
cak165's Avatar
good luck
You sir is a genius, thank you! It was a loose ground at the top of the manifold that came loose. I wouldn't think everything would go haywire like this from a loose ground, but it was...
Thank you, again, TexasHonda!
jriv7
05-08-2020 05:50 PM
bearingman07936
01-07-2016 03:22 PM
jordanboi
09-05-2015 01:33 AM
NSolace
09-03-2015 08:02 PM
Quick Reply: Having trouble starting my TSX (see video) after manifold replacement
