Broken Sway Bar Mount - NOT an endlink
#161
Someone stole "My Garage"
$35? Ok, this means the RSB is worth the chance, as the repair is cheeeeeeeeeap if (and that's a small-chance "if") this were to even happen.
Hell $35 doesn't even cover a tank of gas these days...
#162
Originally Posted by jlukja
I suspect side to side movement isn't as important as letting it rotate inside the bushing.
It may have been asked or said, but did gsclifton mention anything about lube, or lack there or?
#163
ABP TSX
#164
Originally Posted by gsclifton
I used silicon grease the day the ES poly bushings were installed. I never removed and added more grease after the initial install. However, mine were silent. I never heard any squeaking or noise period until the mount broke.
I'm just trying to help gage the whole lubrication thing cause in theory that a few of us are tentative believers in....lol
EDIT: Nevermind, went back and found it. See you installed them Sep 23, 2005 @ 25,112 miles and had it break on Feb 22, 2007 @ 44k miles. That is just about a year in a half without any additional lubrication. Humm....
#165
Summer is Coming
My ![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
If the swaybar is not allowed to move freely within the bushings could it impose a torque on the mount that would, after a period of time, cause failure? I'm wondering if we're barking up the wrong tree. It may not be the swaybar or the bushings but the lack of proper lubrication between the two. Just a thought.
#166
qft
#167
I talked with my welder buddy (he does it for a living) about this whole problem and he said it wouldn't be a problem to "beef-up" the whole area even after it broke. No biggie. Anyone with any high level of skill could do the job and even make it look real pretty (his words not mine). After doing some more research into this my question is, "Is our RSB designed to rotate within the bushing and/or move side-to-side." I don't recall anyone definitive answer to that question. Sorry if I just missed it. I'm still concerned about the load on the endlinks. Has anyone here ever had a problem with them after installing a bigger RSB?
#169
Originally Posted by drkangel348
35$
I took it to a welder in Garden Grove called D.S.G. Metal Fab, they specialize in military and commercial welding and are repair specialists.
The address is:
12850 Western Avenue
Garden Grove, CA 92841
(714) 697-7077
The address is:
(714) 697-7077
drkangel348,
So DSG Metal Fab repaired it and beefed it up too? I'm just curious as to how they beefed it up -- maybe some pic's if it'll show what was done?
#170
Originally Posted by llwtsx
drkangel348,
Sure... I'll take pics sometime this week.
#171
Originally Posted by Rocket_man
This is an interesting theory. When I installed my ES poly bushings I had a hard time getting the bracket to seat all the way on the mount. I hit the torque before the bracket bottomed out. Either I had a slightly thicker bar, or the bushings were a little thick, not sure, but my bushings are cranked down tight on that bar. I wonder if I should put some washers under the bracket and take some compression off the bushings?
I'd like to find some slightly longer, same-or-higher grade bolts, to use next time I lube the bushings. Anyone know the exact spec of the OEM bracket bolts (length, grade, thread, etc...) ??
#172
Originally Posted by PJS
Check what I wrote on page 4.
Yes I read your earlier post. What I meant to ask pertained to the OEM RSB and how it functioned as part of the overall suspension package. Hence with the installation of any stiffer bar and different bushings are we introducing a new movement and/or stress beyond what the mount is designed to handle. Then again the mounts could be just too whimpy and weak in the first place. My welder friend explained to me how the metal would become predisposed to failure as a result of it being bent or stamped. This should not be a surprise to anyone that the weakest link in the chain will be the first to fail. I've decided not to worry about that which has not yet happened and will just end up beefing up those whimpy brackets.
Once you've gone stiffer you can never go back!
#174
Originally Posted by IneedaTSX
Well my mount has been replaced by acura
No more knocking noise!!!!!!!!!!!!
And they covered it under warranty, I'm a happy man!!
#178
To answer your question though, washers will probably not work unless you can get longer bolts. I had a heck of a time getting em in since the washer and bracket were thicker than stock.
And the damn right side zerk is real close to the exhaust pipe, making it real hard to grease. PITA, but now it's done and all is quiet and tight. I'm glad it's done and the car drives great again.
#179
Originally Posted by CL9projektz
whoa how'd you pull that off???
Not sure if everyone will be as lucky, but its worth a shot.
#180
Originally Posted by JTso
Didn't know the mount is available separately from the lower subframe.
I have the paperwork in the car, maybe I can find a part number or something.
#181
Apparently they were able to order that part, called a "lower subframe mount".
I wonder if Acura actually welded it or if the "lower subframe mount" it connectable?
JTso - Can you see anywhere under there where this piece might actually connect to though, cause i can't!
#182
Yea def get that part number cause when i got into my accident in my 04, they had to replace the whole lower frame section that cost like $750 big ones!!
I'll also get under the car and take a look at how it was repaired.
#183
On the paper I did see a price, I think it was like $450....I'll confirm this afternoon.
#184
maybe they cut off the old one and welded the new part in place? like they would do replacing a radiator support?
ineedatsx, how long did it take them to fix your car?
#185
C'mon, man! Row yer own.
#190
Originally Posted by aaronng
And finally.... here it is!
I wonder what's that hole on the right of the top bolt for....
![](http://img213.imageshack.us/img213/6721/bushingkd3.jpg)
![](http://www.tsobad.com/jtso/Images/split%20collar.jpg)
#191
I think this will work a little better. It's called "split collar" and they come in different sizes. Just place the half collar over the sway bar and tighten down the two hex bolts.
#193
Originally Posted by xjohnkdoex
has anyone who purchased and installed the progress bar encountered any of the issues mentioned in the thread yet?
#194
Originally Posted by moda_way
As mentioned before, the Progress bar does not do this because it has rings welded on to the bar to prevent the side-to-side motion.
#197
^^ Alright, we have a mechanical engineer on the case now. ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
TSXnTEX - umm....YES!!! Just go to howstuffworks.com and read up on it!
#198
where is my garage?!
1 Post
my bad, i must've skipped over that nugget of information.
#199
Originally Posted by TSXnTEX
whats the point of a sway bar?!? is it that important?
http://autospeed.drive.com.au/cms/A_2359/article.html
http://auto.howstuffworks.com/car-suspension3.htm
#200
We are working with a couple of issues - stress and lubrication. Somehow these two are being grouped together, so let take a look at them.
- What is the primpary use of lubrication on a swaybar bushing? There isn't a single drop of lube on OEM soft rubber bushings on any cars regardless of how large the dia of the bar. You will only see the application of lube on poly bushing to eliminate noise due to the tight clearance, or lack there of between the bar and bushings. Otherwise, the dealer will have huge amount of squeaky suspension problem calls, or swaybar lubrication would be one of the regular maintenance items.
- Why use poly bushings? We all know the primpary use of poly bushing is to eliminate the flex in the system so the swaybar will react more quickly during turns. However, this also means quicker transfer of stress to the rest of the system (brackets, endlinks).
- How does poly compare to OEM bushing in terms of rate of stress transfer? Let me provide an example hopefully makes some sense (or not). Imagine placing your finger through the opening of a OEM D-bushing. Now place the D-bushing with your finger in it between a bench vise. Now slowly tighten the bench vise until you start to feel the pain (stress). The rubber bushing will collaspe to a certain point until the give is taken up, then your finger will hurt like hell. The swaybar will compress the bushing the same way. Note the thin upper portion of the Comptech bushings are tore to hell in no time? Comptech later switched to a thicker bushing because of this reason. Now, repeat the same exercise with a poly bushing and see the difference.
- Why do poly bushings require maintenance (lubrication)? Well, if the lube doesn't disappear, you will never have to re-lube the bushings. But how do they disappear? Well, the rotating movement will squeeze some of them out, and the side-to-side movement will cause some of it to come out as well, covering the side of the bushings. The amount of lube loss can not be recovered even the bar slides back to the original position. The bushings will simple push it aside due to the tight clearance. Now, what if the side movement of the bar can be reduced? Does it help reduce lubrication loss and thus increase the maintenane cycle? Perhaps.
- How to reduce the side movement? Progress seems to have a good idea on how to do it. In fact, Progress also uses the split collar on swaybars for other cars.
- Does the side movement increase or decrease stress on the brackets? Well, if movement promotes lubrication loss, and loss of lubrication promotes stress on the brackets... Then, what do you think?
- Are the OEM swaybar brackets capable of handling a larger bar like the one for the TSX (22mm)? The size increase from 15mm to 22mm is huge. The 7mm increase with a solid bar can exert large amount of stress. I think someone has provided some data on that.
I happen to be installing a new Progress rear swaybar for my Prelude yesterday. The OEM bar is 23mm and the new bar is 27mm, which is a much smaller increase than the TSX bar (4mm vs 7mm). However, Progress includes a set of heavy duty brackets measure 4.6mm thick and extended the base of the bracket to another few inches to provide more support and adding another mounting hole on the base bracket. Additionally, Progress also offers a replacement set of all metal rod end endlinks to be used with the 27mm bar. All these extra steps are clear indications how much stress can be put on the brackets with a thicker bar.
Why didn't Progress or Comptech include a different set of brackets? I believe they would if they could and should. If you examine the OEM brackets, it's not something that can be easily swapped out like other cars. Neuspeed took another approach which uses a slightly smaller bar (19mm).
I'm not a structural engineer but just a guy who works on cars a lot.
