Broken Sway Bar Mount - NOT an endlink
#122
Summer is Coming
Originally Posted by PJS
If they have technical data, which I would expect them to, then it shouldn't be a problem.
#123
Just a bit of a reality check, I did the math. There will be roughly 100,000 TSXs on the road at the end of 2007. We have 2 people with this issue constituting .002% of the future population. I think we all should liberally (only time I'll use that word
) apply lithium grease to prevent any binding between the bushings and the bar. This should eliminate concerns around side to side movement of the bar. Just a thought.
#124
Driver/Detailer
Done - Whiteline to go, unless Aaron fancies doing that one for us?
18mm = increase of 107% (means 207% stiffness of the original)
19mm = 157% (257% of original)
20mm = 216%
21mm = 284%
22mm = 363%
23mm = 453%
24mm = 555%
#127
Someone stole "My Garage"
I have a question regarding the poly bushings. Does anyone know of a way to keep the grease in the area between the bushing and the bar, without having to get a new set of bushings with the zerk fitting? ie: Can I take a sharp utility knife and cut tiny channels/grooves on the inside fo the bushing, to allow a small area for grease to sit? If I recall correctly, the simple ES poly bushings have no channels in there at all for grease, and it likely gets squeezed out in a hurry with the forces the bar puts on the area.
#128
#129
Originally Posted by aaronng
from 15mm to:
20mm = 216%
21mm = 284%
22mm = 363%
23mm = 453%
24mm = 555%
20mm = 216%
21mm = 284%
22mm = 363%
23mm = 453%
24mm = 555%
Sadly it's useless since no-one knows if the bars are the same material, solid or hollow, wall thickness (if hollow), nor bent in the same position, to the same degree as the OEM.
I've emailed Whiteline and await to see if they reply.
#130
#131
Originally Posted by moda_way
The channels on my zerk fitted RSB bushings are about the width of a utility knife blade and are complete around the circumference. I'd be too afraid of messing the bushing up. I mean, taking the bushing off 2x per year should suffice (waiting for Dr. JTso to chime in). On top of that and making sure you torque the bolts correctly.
Regarding what PJS said about the differences in the bar, i measured the angles of the bar and they were bent in the same manor however, i don't know if the bar is solid or "hollow." You could probably just drop the bar and be able to tell the difference though....lol. I would assume it is solid....
JTso will clear things up
#132
Personally, I strictly use silicone grease for all poly D-bushings. I installed a set on my 98 Civic and I didn't have to re-grease after 7+ years. Same for my truck after 4 years, the Prelude after 3 years. I reapplied the grease for the TSX simply because switching swaybar. The bushings with the grooves inside are the best as it retain the grease better for longer service interval. The non-groove bushings tend to squeeze out the grease when the swaybar slides on the bushings. The Progress bar uses flanges on the swaybar to keep it from sliding or limiting the slide movement, and it uses D-bushings with the inner grooves. The Progress is a better design bar IMO.
#133
Anyone have a part number for the Energy Suspension D-bushings that replace the 22mm ones normally recommended for the Comptech bar, but that HAVE GROOVES?
Or do we have to go with the modify-the-zerk-fitting-bushings-to-fit approach? I'm not concerned with having the zerk fittings, but want the grooves, if possible.
#134
Edit (damn rule): This is the type of bushing I want. If anyone is selling the Progress bushings separate (long-shot, I know), let me know!
https://acurazine.com/forums/showpos...1&postcount=49
#136
The only modifications I had to do to these was hone the the bolt holes closer to the bushing by about 1/8 each side and then make the washer look like a D so they could be closer to the bushing too.
#137
i'm not even sure if the number of comptech rsb modded tsx'es can be attained...
dammit. i have the comptech rsb in my trunk ready for installation too. decisions, decisions...
#138
where is my garage?!
1 Post
Originally Posted by afici0nad0
your 100,000 count only counts for the tsx'es on the road, and does not take into account the number of tsx'es with the comptech rsb mod?
in the poll within the other thread, there are a total of 25 comptech rear sway bar users, 2 of which incurred damage. 8% of users suffered damaged w/ modified competch bars. that's a pretty small sample to judge on, and doesn't even begin to account for other variables such as year of car, other mods, driving style, etc...
still, the fact that this COULD happen makes me really wary of installing my progress bar. but like others have said, i guess that's the nature of modding. you do it at your own risk. even if progress came on here and explained all their research and affirmed that their bar won't break the mounts, who can really say if it will/won't happen?
maybe i'll buy the a-spec suspension and do that first. haha.
#139
Originally Posted by xjohnkdoex
i was thinking of that too regarding the numbers.
But the RSB makes such a difference! It really drives like a different car... I couldn't beleive it after I drove it last night after it was installed.... you stay FLAT I love it.
#140
Driver/Detailer
Thanks Aaron for quoting what any of us could've pulled off Whiteline's site.
#141
remember, the poll only figures in members of acurazine. who knows how many owners worldwide are rsb-upgraded, has/has not experienced issues, and are not familiar with acurazine and/or have not participated in the poll...
having said that. the discussion here has made me become more aware of the potential problems. this thread is great, and as long as members continue to express their opinions/experience, we'll all find fixes (other than the ones already discussed here).
#142
to add to my post above. i'd like to hear the experiences of the owners in singapore. i know we do have a good number here, and from past pics, threads, it seems as if they do track the car on an occasional basis.
#143
As with everything, it is just an estimate. I just posted that up to save people the trouble of dlding the whiteline PDF.
Still no news from the others yet.
Must also clarify that the Swift numbers are against the Euro R OEM bar, which we suspect is stiffer than the TSX/Accord CL9's.
So, it skewiffs the position slightly since I would expect the others to come back with numbers compared to the CL9's.
#144
#145
Driver/Detailer
Ah! Okay, fair dinkums.
#147
Driver/Detailer
I thought it was 15mm, like the TSX's, and it was the Accord 2.4's that were 14mm?
The USDM and AUDM Accords are not a CL series though...
#149
I was looking at it as an overall failure rate of that specific part on the car, regardless of modification or not. Even so, I think it is pretty reasonable to say that if you keep that bushing liberally greased, you should have no reason to have this issue.
#151
I had this happen to me a little while ago...
Find an welder that handles industrial work... thats what I did.
I just showed them how the RSB was supported and they took it over from there...
Either that or find a place that welds roll-cages or specializes in 4x4/off-road welding.
The place that I took it to had a sign out front that said "Welding no job too small". :P
#152
drkangel348: Out of curiousity, what did that cost you? It might help everyone looking at the RSB from a cost-effectiveness standpoint, factor everything into the equation better. ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
aarong: Do you really think the rubber hose will prevent the RSB from shifting at all? Rubber is inherently very soft and pliable -- I'd think that w/ the forces required to move a RSB, that the rubber would just compress/flex and not really do anything. Just wondering...
#153
Driver/Detailer
#154
#155
#156
Originally Posted by Spoon
That's kind of like looking at the incidence of lung cancer in the population, not differentiating between smoker and non-smoker, and concluding that just a few won't kill ya.
I agree with your overall assertion though, that the probability of this happening seems to be low, based only on the people on this board. However, it seems to be somewhat of a pain in the ass to get fixed, if you are unlucky enough to have it break on you, so the risk is not insignificant.
#157
My ![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
I crawled under today to take a look. With great relief I discovered no cracking or spiderwebbing or any other evidence of impending failure. I decided to re-lube the ES bushings. When I took the bushings off I noticed that they were slightly worn on the inside, like they've been rubbing against the swaybar. There were even remnants of polyurethane on the swaybar itself. I cleaned off the bar and wrapped it with teflon tape this time. I still had some of the lube that came with the bushings so I again coated the inner surface of the bushings with lube. This is when I noticed that this lube is not very slippery. When I got some on my fingers and rubbed them together it felt very "tacky" and "gummy". It certainly didn't feel like it would allow the bar to slide back and forth through the bushing or allow it to rotate easily within the bushing. I reassembled everything and, so far, no squishing noise. But, I'm wondering if the next time I lube the bushings I should use lithium grease.
If the swaybar is not allowed to move freely within the bushings could it impose a torque on the mount that would, after a period of time, cause failure? I'm wondering if we're barking up the wrong tree. It may not be the swaybar or the bushings but the lack of proper lubrication between the two. Just a thought.
#158
Driver/Detailer
![Cry](https://acurazine.com/forums/images/smilies/cry.gif)
#159
T
It could be. That also means my RSB with the locking kit will have more stress.![Cry](https://acurazine.com/forums/images/smilies/cry.gif)
#160
What's the name of the place you took it to?
I took it to a welder in Garden Grove called D.S.G. Metal Fab, they specialize in military and commercial welding and are repair specialists.
The address is:
12850 Western Avenue
Garden Grove, CA 92841
(714) 697-7077
