Apply brakes...wheel jerks to one side
Here is a new one....
Getting on the brakes quickly, lets say if someone cuts in front of you and you quickly need to scrub some speed, the quick, initial application of the brake results in the steering wheel jerking to the left side. Its almost as if the left caliper was hitting the rotor just slightly before the right one is. Nice, soft application of the brakes doesnt result in this behavior.
Anyone?
Anyone?
It could be several things -- and this is one of those problems that might be solved by doing something; without first making an accurate diagnosis. Also known as "Easter Egging".
I would have an experienced mechanic take a look. It might be pads, rotor, or even the ABS. But, it is not likely that the mechanic can say, "Your problem is due to....".
So, I would expect that he would recommend changing the brake pads, and perhaps truing the rotors, as a starting point.
Someone stole "My Garage"
If the car jerks to the left, then it's likely that one or both of the calipers on the right side of the car is partially seized. When was the last time you had the brakes serviced? Have someone (or do it yourself) lube the slider pins and all other areas of the brake that should be lubed, and I'd bet your problem is solved.
It's not hard to take the brakes apart and lube the pins, and it's nearly free (the brake caliper lube is < $10 and the labour is free if you know what you're doing and/or can read the Helm's manual.)
And...as if on queue, the dealer tells me the squeal is "normal."
My a$$ it is.
Curls...Im hearing you and I have the knowledge to do that...but not the tools. After it took me four hours to swap a standard Chevy offset starter in my old Camaro, I swore off working on cars forever, unless I had a lift, air and the tools.
So Im gonna take it to the dealer.
My a$$ it is.
My a$$ it is.
My a$$ it is.
Originally Posted by jlukja
Jebus, I need to get my ass to my dealership so they can fix my non-squealing abnormal brakes.
We should make a sticky "Top Ten Dealer Excuses for Being Too Lazy to Diagnose a Problem."
The only tool you need is a beefy socket wrench and a 17mm or 19mm socket (can't remember which). Grease up the pins and the places where the pad slides in the caliper. Pull the pads out, pop off the shims and put some anti-squeal compound on the back of the pad. Put the shim back on the pad and reinstall. Since you're just putting the same pads right back on you won't even have to deal with compressing the piston again.
You might as well grab some brake parts cleaner to clean stuff up while you're at it. A barely competent mechanic could do this in an hour easily.
Originally Posted by Newplay1
When I do sudden stops my steering wheel shakes alittle, possible brake/pad related?
FOLLOW UP:
Dealer inspected both calipers.
One of the front slider sticking was the cause, as suspected.
All sliders broken down and relubed.
Problem fixed!
Problem fixed!
Cheers,
Eric
nanos
11-12-2015 08:41 PM
