another semi-auto tran question
when your shifting do your let your foot off the gas then shift then gas again or something like that or just keep foot on gas and keep going.
i am new with shifting and shit sorry guys i am newb
No need to lift to shift. The automatic transmission in the TSX is just that. It's programed to allow shifting it yourself, but it's in no way related to for example the DSG transmission found in some VW/Audi products. That transmission is a manual transmission with an electronic clutch.
Make a hole, coming thru!
Think he's referring to Sequential SportShift mode (SSM), as in the other thread.
I've tried to find a sweet spot with the drive by wire throttle, and it's just not as clear cut as with my other manual (transmission) vehicles. Not having a "friction point" to learn makes it tough with the SSM. Trial and error has got me learning just how much to let off the gas without overrevving the engine while the tranny shifts. But I still miss the mark regularly, and make this awful, amateurish reeVVVV sound as I'm shifting. Maybe I'm having to unlearn years of throttle adjustment learned in an '77 MGB, '82 Accord LX, and '87 Jeep Wrangler.
My ... let off the gas while you're getting accustomed to SSM. Then start experimenting a bit with the shift 2->3 or 3->4 (the latter being the easiest to experiment with, IMHO). As always, practice good judgment, do this where there are no other cars or pedestrians about. We don't want your next post to be about your first crash.
Not to argue with you, but when I first got mine, and still does this,... I kept my throttle at the same point while doing SSM, the engine would race to the redline during the brief shifting delay. I moved the shift lever to the up position pretty swiftly too. Maybe something's wrong with my tranny?
Simba, old chum, I stand corrected. I think when I was trying SSM early, I was accelerating like a bat out o' hell, with the pedal to the metal. Today, coming home, I tried just keeping my gas pedal in the same position while snicking through the SSM gears. Worked fine, very little lag or overrevving noted. Thanks, I learned something from you (again).
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
