Acura TSX Maintenance
Hey guys I am looking at an 2004 Acura tsx with 135,000 kms on it and I was wondering what the car should have got done for a 135,000 car and fixes that may come when I get the car.
Thankss
Datboi
Thankss
Datboi
Modding newbie
It's an '04 so check on the AC and see if it's been fixed or not. I've heard it's an ongoing problem for those that it's a problem for. (That made sense in my head, so hopefully it does in writing too.) If it's been changed, you may be looking at having to do it again soon, so expect that expense. If it hasn't, it's a good one and you probably won't need to.
It's a 6 year old vehicle, so your suspension is 100% worn out if it's still original and you'll have to replace that. Well you don't have to, but you will if you're considering a nice vehicle. Also have a mechanic you trust check out the steering and drivetrain components to make sure all is ok. Alot can happen in 6 years and about 100,000 miles.
Obviously, ever fluid in the vehicle will have to be changed so expect that expense. Normal wear and tear items should be looked at. Brakes, rotors, clutch, tires... A 2,000 dollar vehicle that requires new brakes, rotors, tires, a clutch, and axles is more expensive that a 4,000 dollar vehicle that doesn't. Follow what I'm saying?
A carfax type report couldn't hurt, but could reveal problems, assuming they were reported to carfax or your choice of reporting service. Just bear in mind that the car could have been extensively damaged even if nothing shows up in such a report.
Please don't let my post scare you, it's just as likely that the car will need no work at all and is a wonderful deal. I just wanted to point out some of the things to look for when looking for a used vehicle.
There is nothing you can do with the A/C until it breaks. For some, they've had this issue more than once, but for others, not at all. Fortunately, I've been lucky with my '04.
As for any issues, you can use the search function to look up threads in the forum.
But... all that said, I'd only consider it if it was a really good deal. Though some here will differ (which is good, that's what this forum is for), there have been too many 04 horror stories related in threads in this forum for me to give an 04 a second look unless the price was really right; even then I'd probably look for an 05 (like mine with almost 114K miles on it). The 04's do seem to have more than it's share of the "first year" blues.
Sweet!
I have an '04 with 121k miles on it and other than the A/C issue it's been a solid car. I was fortunate enough to have the A/C system fixed under warranty. 1st time around the entire A/C system was replaced, and the 2nd time around (like less than 1k miles after work was completed) they replaced the replacement compressor . This was all around 90k miles...so the A/C system has been solid since then! *knocks on wood*
Itchytoe - I wouldn't assume that the car's suspension is 100% worn out. I haven't replaced any suspension components and everything is still within spec. I guess this depends on how the car was driven, the conditions it was driven in, and where the car was driven.
acura_dipset_tl
01-01-2016 03:02 PM
Zonian22
11-14-2015 01:20 PM
Zonian22
09-02-2015 08:19 AM
