Acura ServiceNews Bulletins
IMPORTANT NOTICE
UPDATED 5 OCTOBER 2010
Honda has removed our access to the bulletins.
I don't know if or when we will ever be able to access them.
I will open the thread and change this notice if we regain our access.
Ron A
Click on the Month and Year below.
2010
July 2010
June 2010
May 2010
April 2010
March 2010
February 2010
January 2010
2009
December 2009
November 2009
October 2009
September 2009
August 2009
July 2009
June 2009
May 2009
April 2009
March 2009
February 2009
January 2009
2008
December 2008
November 2008
October 2008
September 2008
August 2008
July 2008
June 2008
May 2008
April 2008
March 2008
February 2008
January 2008
2007
December 2007
November 2007
October 2007
September 2007
August 2007
July 2007
June 2007
May 2007
April 2007
March 2007
February 2007
January 2007
2006
December 2006
November 2006
October 2006
September 2006
August 2006
July 2006
June 2006
May 2006
April 2006
March 2006
February 2006
January 2006
2005
December 2005
November 2005
October 2005
September 2005
August 2005
July 2005
June 2005
May 2005
April 2005
March 2005
February 2005
January 2005
2004
January 2004
February 2004
March 2004
April 2004
May 2004
June 2004
July 2004
August 2004
September 2004
October 2004
November 2004
December 2004
2003 (OCT-DEC ONLY LISTED HERE)
October 2003
November 2003
December 2003
Ron A
2010
July 2010
June 2010
May 2010
April 2010
March 2010
February 2010
January 2010
2009
December 2009
November 2009
October 2009
September 2009
August 2009
July 2009
June 2009
May 2009
April 2009
March 2009
February 2009
January 2009
2008
December 2008
November 2008
October 2008
September 2008
August 2008
July 2008
June 2008
May 2008
April 2008
March 2008
February 2008
January 2008
2007
December 2007
November 2007
October 2007
September 2007
August 2007
July 2007
June 2007
May 2007
April 2007
March 2007
February 2007
January 2007
2006
December 2006
November 2006
October 2006
September 2006
August 2006
July 2006
June 2006
May 2006
April 2006
March 2006
February 2006
January 2006
2005
December 2005
November 2005
October 2005
September 2005
August 2005
July 2005
June 2005
May 2005
April 2005
March 2005
February 2005
January 2005
2004
January 2004
February 2004
March 2004
April 2004
May 2004
June 2004
July 2004
August 2004
September 2004
October 2004
November 2004
December 2004
October 2003
November 2003
December 2003
Notices:
This was shamelessly copied from the TL Forum. Its a good source of information and makes interesting reading so it'll remain a sticky.
I will update this every month. The bulletin is usually available around the 10th of the following month, so if I don't update it by then, send me a PM.
Do not whore up this thread. Post only if you have something worthwhile to add.
Thanks to joerockt for suggesting that TSX Forum have this available as well.
October 2006 Added
Added link to the October 2006 Bulletin. Items that may be of interest to TSX owners are:
- Whiny ATs (pg.2)
- AT engagement shock/noise (pg.3)
- No 60sec. headlight auto off delay (pg.3)
- Whiny ATs (pg.2)
Someone stole "My Garage"
Originally Posted by TSXnOPKS
Are the Nov/Dec 06 editions available?
November 2006 and December 2006 added
Sorry to be so late with the update, I've been slacking
Added link to the November 2006 Bulletin. Items that may be of interest to TSX owners are:
- Rewriting ODO Data to a New Gauge Control Module (pg.1)
- Troubleshooting B-CAN and F-CAN DTCs (pg.3)
- Navigation System Map Matching (pg.3)
- Navigation System Doesn't Map Match or Gets Lost (pg. 3)
- Know your Tire Pressure Indicators (pg. 5)
Also added link to the December 2006 Bulletin. Items that may be of interest to TSX owners are:
- Never use Chrome Wheel Cleaner on Alloy Wheels (pg. 1)
- Troubleshooting Speakers? Use the Audio Diagnostic CD (pg. 2)
- Specialty Hotlines (pg. 3)
Because Of You
Thanks for the post.
I have read all of them. For those of you who don't want to read all these, I think these are the most significant:
To test for wind noise, use a leaf blower.
Flushing the automatic transmission can damage the A/T.
Worn battery may have enough power to crank the engine but may not have enough power to power up the Immobilize System. So, it may crank but the car may not start.
The radio display is blank or does not light up. This may be caused by holding down the CD/AUX button for more than 5 seconds.
January 2007 added
Added link to the January 2007 ServiceNews Bulletin. Items of interest to TSX owners:
- Stiff Shifting?, Popping Out Of Gear?, Replace the MTF (pg. 1)
- Engine Cranks Doesn't Start after MT Overhaul (pg. 1)
February 2007 Added
Items that may be of interest to TSX owners in this issue are:
- Replace solenoids or replace A/T. How to decide (pg. 2)
- Steering wheel vibration? Could be cold flat-spotting (pg. 2)
- Oil film at top of damper working chamber is OK (pg. 3)
- HomeLink: Before you troubleshoot, consider this (pg. 6)
- Proper care and feeding of an Acura battery (pg. 6)
Because Of You
Originally Posted by jlukja
Which bulletin was this in?
I will go over all of them when i am not too busy later next week... need to go to different chemical plants to do inspection!!! been sucking up all kind of toxic for couple days!!!!
sorry I didn't write it down (I should write it down... )
March 2007 Added
Added a link to the March 2007 Bulletin. Items of interest:
- New Daylight Saving Time Schedule Poses Navi Clock Problem (pg. 1)
- Outside Temperature Indicator Logic Explained (pg. 2)
- Audio HVAC Display Is Dim Or Dark: Some FAQs about S/B 04-021 (pg. 3)
- Electronically Retrieving Audio Unit Serial Numbers (pg. 4)
- Service Manual Fix: Lubricants and Fluids (pg. 4)
April 07 added
Added a link to the April 2007 Bulletin. Items of interest to TSX owners:
- Replacement HID headlight bulbs look yellow at first (pg. 2)
- Wait 10 min. before measuring parasitic current draw (pg. 3)
May 2007 bulletin added
Added a link to the May 2007 Bulletin. Items of interest to TSX owners:
- New policy for steel and aluminum wheel repair (pg. 1)
- HFL locked and forgot the password? Read this (pg. 2)
Originally Posted by carcrazyboy68
how do u read the files? its not working for me
June 2007 Added
Added link to June 2007 ServiceNews. Items of potential interest to TSX owners:
- Install Accessory Wheel Locks the Right Way (pg. 3)
- Replacing The Engine Block? Replace the Coolant Separator, Too. (pg. 4)
July 2007 added
Added a link to the July 2007 Bulletin. Items of interest to TSX owners:
- Normal Tire Pressure Loss Isn't A Warranty Repair (pg. 1)
- Use This Handy Chart To Describe Transmission Problems (pg. 2)
- ATF Cooler Cleaning Gets Its Own Flat Rate Time (pg. 5)
- Aftermarket Window Tinting Can Cause Noisy, Binding Windows (pg. 5)
August 2007 added
Added a link to the August 2007 Bulletin. Items of interest to TSX owners:
- Check Out These VSA Troubleshooting Tips (pg. 1)
- Relay Puller Tool Now Available (pg. 3)
- A/C Condenser Replacement Tips (pg. 4)
- Electronic Component Troubleshooting Tips (pg. 5)
Added the September 2007 Bulletin. Items of possible interest to TSX owners are:
- Remember to Reset Power Windows Control Unit (pg. 1)
Posted link to the October 2007 edition of Acura ServiceNews Bulletin
- Excessive Steering Wheel Shimmy or Chassis Vibration, Part 1 of 5 - (Pg. 1)
- Trunk Opener Not Working? - (Pg. 5)
November 2007 added
Added a link to the November 2007 Bulletin. Items of interest to TSX owners:
- Inflating Tires for Low Tire Pressure Indication is Not a Warranty Repair (pg. 1)
- Window Film Can Block Electronic Device Signals (pg. 1)
- Blue Arrows Mean One-Way Traffic (pg. 2)
- Male Voice Promps Gone From '08 Navi DVDs (pg. 2)
- SRS Indicator On With SRS DTC 81-79 After Body Work (pg. 2)
- Excessive Steering Wheel Shimmy or Chassis Vibration - Part 2 of 5 (Pg. 3)
- Security System Sounds By Itself (Pg. 4)
- A Troubleshooting Guide to Handsfree Link - Part 1 of 5 (Pg. 4)
December 2007 added
Added a link to the December 2007 Bulletin. Items of interest to TSX owners:
- Excessive Steering Wheel Shimmy or Chassis Vibration - Part 3 of 5 (Pg. 1)
- Replacing Just Two Tires? Mount New Tires on the Rear (Pg. 1)
- A Troubleshooting Guide to Handsfree Link - Part 2 of 5 (Pg. 2)
January 2008 added
Added a link to the January 2008 Bulletin. Items of interest to TSX owners:
- Check Out The Latest Word On A/T Flushing (pg. 1)
- VSA Activation Indicator Stays On After Doing S/B 07-041 (pg. 4)
- Excessive Steering Wheel Shimmy or Chassis Vibration - Part 4 of 5 (Pg. 6)
- A Troubleshooting Guide to Handsfree Link - Part 3 of 5 (Pg. 10)
February 2008 added
Added a link to the February 2008 Bulletin. Items of interest to TSX owners:
- Ticking, Creaking, Popping, or Rattling from Front Door (Pg. 2)
- Navi Display Won't Switch to Night Mode With Headlights Turned On (Pg. 6)
- Excessive Steering Wheel Shimmy And Chassis Vibration - Part 5 of 5 (Pg. 9)
- A Troubleshooting Guide to HandsFreeLink - Part 4 of 5 (Pg. 12)
my car was actually in the shop today to get a new transmission. i saw the creaking door article and called them right away and told them about my problem. the service manager wouldnt' budge until i told them a relative of mine sent me this service bulletin then he finally said he'll do it for me. hopefully they won't screw it up since i got a feeling this is the first time they've gonna try it
jlukja: can you update it to add the March and April editions?
The April one has a few TSX-related items that might help people here.
Links to March and April 08 Bulletins added
In the March 2008 Bulletin, TSX items of interest:
- Now Available: Extreme Cold Weather Coolant/Antifreze Type 2 (Page 4)
- VSA Activation Indicator On After VSA Modulator-Control Unit R&R (Page 6)
- MIL On With DTC P0171 or P0172? Check For An Aftermarket Air Intake (Page 9)
The Servie Article says this is applicable to MDXs and RDXs but its interesting to
note the recommended approach when dealing with aftertermarket parts
- Stained Paint Under the Wrap Guard? It's Just Trapped Moisture (Page 10)
- A Troubleshooting Guide To HandsFreeLink - Part 5 of 5 (Page 11)
In the April 2008 Bulletin, items that may be of interest to TSX owners:
- Leaking Head Cover Gasket May Just Be a Residual Oil Trail (Page 1)
- Can't Turn Off The VSA? Check If The TPMS Indicator Is On (Page 2)
- Electrical Problems? DTCs? Check For a Bad Negative Battery Cable (Page 2)
Link to May 08 is up
Items that may be of interest to TSX owners:
- Use Throttle Depressor Tool For A/C System Performance Test (Page 1)
