Acura Service Bulletin: 04-042 Rattle from A-pillar
Old 08-15-2005, 01:17 AM
  #41
05t
3rd Gear
05t's Avatar
Originally Posted by Dan Martin
That's the B-Pillar and it's probably just the window rattle that can be fixed with a little spray lube (not WD-40).
could you elaborate on this? my rattle sounds like it is coming from b pillar too...
what kind of spray lube and what/where am i spraying?
Old 08-15-2005, 07:46 AM
  #42
CarKnack's Avatar
I'd like to know if there's a thread somewhere that contains a list of all the service bulletins Acura HAS put out in one place. I'm about to go for 20k service and would like to have some company paper in my hand....
Old 08-15-2005, 08:09 AM
  #43
She said: it's GINORMOUS!
mg7726's Avatar
they have all the TSBs listed at Acura World, click for the pdf
http://www.a curaworld.com/tsb.html (remove space on the link)
Old 09-02-2005, 11:38 AM
  #44
ASpecTSX's Avatar
Originally Posted by dmbfan36_23
cconrad - do you have an '05? I picked up my 2005 and when I hit between 75 and 80mph i start to get a rattling noise from the passenger side in the front.. either the dash or up near the visor... if this does affect 05s it sounds like I have it!
I've got a 2005 w/ 1400 miles and I'm having the exact same problem. It only seems to get really noticable at highway speeds, 70+ mph. Let me know if you get this looked at anytime soon. I plan on taking mine in to have it checked out next week.
Old 09-03-2005, 10:05 AM
  #45
miner's Avatar
If you have a body kit it is the side strake making the noise because the mounting pins do not keep the brackets tight against the bottom of the car.
Old 09-06-2005, 07:09 AM
  #46
dmbfan36_23's Avatar
I got my initial rattles fixed...
- APillar (it disappeared after a couple hundred miles)
- Moonroof (they adde sealer and repositioned the glass)
- OEM Underbody kit (side skirts) -- see this thread:
https://acurazine.com/forums/showthread.php?t=24633
Now I have a new rattle.. back windsheild... need to search the forums
Old 01-13-2006, 11:33 PM
  #47
divpres's Avatar
I have had the "dash noise" since I purchased the car in Sept. Today I tried slipping a couple of business cards under the outside windshield molding and lo and behold, no noise. I then added WD40 under the molding to eliminate the friction. This worked as well.
Zonian22
11-14-2015 01:20 PM
lland
10-04-2015 04:47 PM
PortlandRL
09-14-2015 12:01 PM
asahrts
09-04-2015 05:55 PM
Quick Reply: Acura Service Bulletin: 04-042 Rattle from A-pillar
