2005 tsx cooling/AC problem
Hey there everyone, I need some help. About three weeks ago I noticed my tsx automatic was slugging the heat of the day(SouthCarolina) , especially in red light traffic. In the cool of night runs great. Anyways, 2 weeks ago I noticed the temp gauge move to the half mark with the ac on. The car gets extremely sluggish n ac blows warm when still. If I turn the ac off it settles down. I've replace the thermostat n bled system for bubbles. Both fans work, changed ac clutch relay, coolant and freon are good n no Leaks as far as I can tell. Am noticing when at a stand still , the. Condenser clicks on maybe five seconds n back off but blows cool those five seconds. Start driving n blows cool again. I'd appreciate any help in advance... Thanks everyone
A short run time on compressor means either excessivley high or low pressure was encountered. Hi/Lo switch senses the pressure and opens to protect the compressor. Too low pressure is more likely but professional help needed to determine which is the case.
good luck
good luck
A/C DIY are always tricky because to diagnose you need the right tools and equipment since it is a sealed system. If nothing else, just take it to a pro that you can trust and have it looked at. Good luck.
Jeremy25
06-17-2016 11:11 PM
GWEEDOspeedo
01-15-2016 10:39 PM
