2004 TSX - Driver Side Vents not blowing as hot as passenger and weaker airflow
Hey guys,
I recently noticed that my Driver side vents take a lot longer to warm up than my passenger side vents. The heat also maxes at a cooler temp and blows weaker than the passenger side of the vehicle. The old Blend Door Actuator had 2 settings, It would be fully closed on Low, but the moment I turned it any hotter it would open a considerable amount and not move anymore. I replaced the Blend Door Actuator, it seemed to rotate correctly the moment I plugged it in but the temp and airflow was still off from the right side.
I let the car sit overnight and the "new" blend door actuator I put in ( I got it off a junkyard accord) is back to acting like the original Blend Door Actuator. I have many other electrical issues but I don't know if its related or not. What could the problem be?
Raver27
5G TLX Problems & Fixes
12-24-2020 08:34 PM
