04 TSX sounds like a boat.
Old Sep 25, 2006 | 01:14 PM
Alucard13's Avatar
Jerk Monster
In the last few months while driving st above about 40mph it sounds like I have a turbine engine in the back of my car. At first I thought it was abnormal road noise because my tires were worn. Yesterday I got new tires and the noise is still there. It's a loud low pitched whirring kind of like an onboard on a boat. Any ideas? One of the guys says it could be a bearing, but I've never had that happen to me before so I don't know where to begin in diagnosing let alone fixing that. By the way the car has 70,000 miles if it is a bearing is that normal for the mileage, I had a prelude that I ran into the ground with 250,000 miles before my sister totalled it and never had this problem. Thanks
Old Sep 25, 2006 | 01:37 PM
moda_way's Avatar
A pothole can make a bearing go after a few thousand on it, soo.....
It does sorta sound like a bearing due to its very precise area of noise.
Old Sep 25, 2006 | 02:00 PM
iamhomin's Avatar
04 remembrance
It's the wheel bearing. Happened to me as well.
Old Sep 25, 2006 | 02:17 PM
curls's Avatar
Someone stole "My Garage"
Does it get worse/louder when slalom-style turning? (find an empty parking lot and have fun!).
If it gets worse when turning left in the slalom, its the right-side bearing. Oppsosite holds true for the left bearing.
Old Sep 25, 2006 | 02:36 PM
Alucard13's Avatar
Jerk Monster
How do fix it?
Old Sep 25, 2006 | 04:45 PM
TSeXer's Avatar
Yup,
Wheel bearing. Both of my rear bearings went @ 53K miles. Acura covered the parts and I paid $345 labor plus $100 diagnostic fee. That was a fun experience. Not to hijack the thread but this car has had more crap go wrong with it than any other car I have had. If you are out of warranty, you can buy the parts for $150 a set and do it yourself. It does not seem like it is a difficult job. They are sealed units so you do not have to pack them. Good Luck
Old Sep 25, 2006 | 05:02 PM
curls's Avatar
Fix is easy: replace bearing unit on affected side(s).
Labour shouldn't be hard at all, especially if you have access to an impact driver, IIRC.
TSeXer: You got ripped off on the labour - $345 for two rear bearings? That's 4 hours of shop time... WAY too high for that job, IMO.
Old Sep 25, 2006 | 05:07 PM
crfortin's Avatar
Wheel Bearing ...
as mentioned severe pot hole or a bad batch of bearings (hope not) could get this started.
Get it fixed right away. Wheel can fall right off and it is very dangerous. You could die.
Old Sep 25, 2006 | 06:17 PM
TSeXer's Avatar
I totally agree. I've done them before on other cars (at like 120K miles). It is a 2 hour job. They wanted $500 at first for the labor. I called Acura Customer Service and they agreed to pay for the parts and got me "discounted labor". The way I figure, it was going to cost me around $300 for the parts and then my time to do the job. At the end of the day, wheel bearing should not go at 53K miles. I am not too happy with the whole situation.
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
Brandle34
Sep 23, 2015 07:20 PM
Iain MacLeod
Sep 17, 2015 01:01 PM
cak165
1G TSX Problems & Fixes
Sep 16, 2015 08:17 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
