Pics / Dyno Video / Chart - Supercharged TSX at Comptech (No 56K)
Rep'n Taxbrain.com
I was down at Comptech this past Wednesday getting some stuff done.
-Had the Denso Iridium IK22 Spark Plugs installed
-Had another bung put in my header for the O2 sensor, I'm running a PLX M300 to monitor my air/fuel ratio
-Found out there is already a spot for a boost guage hose in the intake manifold so I don't need to T tap into one of the other lines
-Did Dyno runs, Comptech made sure my TSX was still running well.
Video of my Dyno run (Taken from 2K RPMS to the Rev Limit):
http://media.putfile.com/Kennys-TSX-...-Comptech-Dyno
I'm a little disappointed in the Dyno runs. It was really hot that day. The dyno room temp read 104 degrees with everything running. We're having a nasty heat wave in NorCal right now. Last time I dynoed it was February so it was probably about 40 something degrees cooler. That 40 degrees difference in temp lead to lower numbers and my car producing less boost. I was producing 4 lbs of boost instead of 5 lbs of boost.
My peak HP was 218 whp and peak TQ was 160. These numbers are a little lower than my previous dyno with SC. In my last dyno, I had 223 whp and 165 TQ peak, but I've since added the Random Tech Hi Flow Cat, so I was hoping for higher numbers. Considering the big temp difference I'm not surprised though. Temp makes a big difference as illustrated by JTso in this thread: http://www.acura-tsx.com/forums/showthread.php?t=31171
Green = February Dyno - 60 degress outside, Comptech SC, Icebox, DC header
Blue/Red = June Dyno - 104 degrees outside, Comptech SC, Icebox, DC header, Random Tech High Flow Cat
Difference in Temp = 44 degrees warmer in the most recent dyno
Components added = Random Tech Hi Flow Cat
Dyno w/ Air/Fuel Ratio
Dyno w/ TQ
My car on they dyno (Notice the fan they use
My car w/ the dyno sensors hooked up
New O2 sensor in header w/ bung from Comptech Header
Temporary Mount Location for PLX until I figure out where I want to put it.
Rest of the pics I took:
A customer's ride they just finished:
Comptech's Supercharged TSX 6MT test car
Asked them about the grill and it's straight custom. They made it themselves and said it took awhile to make so it won't go into production
Machine shop - Every single part is custom made welded by a real person, no machines. In this pic the guy is making a TL exhaust.
Sweet ride I saw in SoCal (Completely off topic, I know )
Dyno w/ TQ
Rep'n Taxbrain.com
Could a mod please fix the above. I had the colors flipped. Green is the newest dyno, from Wednesdsay, in the hot weather.
Blue/Red = February Dyno - 60 degress outside, Comptech SC, Icebox, DC header
Green = June Dyno - 104 degrees outside, Comptech SC, Icebox, DC header, Random Tech High Flow Cat
On paper that doesn't look like much of a difference from stock. However, how does your car feel with the SC on it? Is there more of a difference in the midrange? 6th gear? Your impressions?
Rep'n Taxbrain.com
It's night and day difference in terms of the feel.
Also. I have an Automatic, so I don't have 6th gear.
My car baselined at 165 whp and 138 tq in cold weather. Here's the dyno for those runs. Baseline vs. Modded (w/ no hi flow cat)
W/ the SC and other mods it hit 223 whp and 165 TQ.
These numbers are all measured at the wheels on a Dyno Dynamics Dynamometer:
The red line is a completely stock Auto TSX with OEM ECU, OEM intake, OEM header, OEM Cat, and OEM Exhuast.
The blue line is a TSX with Comptech Supercharger, SC Hondata Reflash, Comptech Icebox, DC Header, OEM Cat, and OEM Exhuast.
Peak Horsepower is now 223 whp, up from 166 whp stock.
The Biggest horsepower gain was 59 whp @ 7100 RPMs
Peak Torque is now 165 ft/lb, up from 138 ft/lbs stock.
The Biggest torque gain was 43 ft/lbs @ 7100 RPMs
Rep'n Taxbrain.com
Originally Posted by jmathew34
nice pics, sound really nice!!
Rep'n Taxbrain.com
Originally Posted by iterry
Wow, that is a difference. Any reliability problems? Now that you have had it a while, any overall impressions?
https://acurazine.com/forums/showthread.php?t=28196
Rep'n Taxbrain.com
104 degress? Jesus.. I couldn't survive over there. I would die if it is above 85 degrees and i'm not at the pool or beach.
In any event, I was curious as to why you had the Denso IK22 installed as opposed to the IK24 that comptech had sent another TSX SCer who was having some issues.
It is interesting that the heat caused it to only pump out 4lbs of boost. I would have thought it was something with the belt.
I'm really impressed with the details I've heard about the Comptech supercharger package... Especially considering how the stock TSX is already borderline when it comes to compression and tendency to ping. It makes me secretly want to buy one or at least have access to a factory sponsored tuner car (ala AMG for Mercedes or M for BMW) which has one of those bolted to the head.
How sensitive is the engine to fuel quality--does it ping much when it is really hot outside?
so did they replace the spark plugs for free? What are they going to do with the rest of their customers, are they going to contact them. Hmm looks like I'll be giving them a call on monday. By they way, did you install a boost gauge?
Rep'n Taxbrain.com
And I thought the low boost would be the belt slipping too but it wasn't. We checked it in between runs and by tightening it on the 2nd run we got 4.1 psi instead of the 3.8 psi on the previous run. So by tightening it, we gained about .3 psi of boost.
frgn sweet k-rock! Lucky!! Comptech what??? Great pics and write up my myspace compadre. Thats like almost like 80hp more than my turd dyno'd. Ride looks good my man!
Rep'n Taxbrain.com
Originally Posted by JTso
Thread cleaned up and fixed dyno numbers.
Yeah, hot temp will kill performance quick. It's especially danger for a SC setup without intercooler.
I can hear the audio but can't see the video. It sounded like a fighter jet taking off!
Rep'n Taxbrain.com
any thoughts on if the ethanol mixture in gas will hurt a s/c'd tsx?
http://forums.clubrsx.com/showthread.php?t=390928
Rep'n Taxbrain.com
I just put the video up on Google video. Hopefully you guys can see it:
http://video.google.com/videoplay?do...38483033311659
And no problems so far with the transmission CG
I asked Comptech if they thought I should run High Temp Auto Tranny Fluid and they said since I don't go to the track I should be fine. They took a TL to the track a couple months ago and did some testing.
Drives With Hands
Rep'n Taxbrain.com
Rep'n Taxbrain.com
Check out how much the engine moves at the end of the video! I think ETD is a must.
Originally Posted by kangjin
Have you noticed a difference with the colder plugs?
Nice trip report! Looks like the RT cat made you lose power.
Were you able to see the Comptech TL? Someone on the TL boards had the chance to drive it.
He mentioned that with VSA on, the car feels like stock due to serious traction issues with all that power.
Rep'n Taxbrain.com
No, I didn't get a chance to drive it. I was too busy with everything with my car. I should have asked though. Maybe next time! What I really want is a ride in one of the NSXs though
