Neuspeed sport suspension installed [56k needs alignment]
Drives With Hands
I finally got my Neuspeed sport springs and Neuspeed Konis installed this week. Nothing out of the ordinary, really. In fact, this is the exact same setup as virtualbong's TSX - right down to the Ingalls rear camber kit.
The advertised drop for these springs is 1.5" F and 1.0" R, but just like others who have used these springs on this board (JTso, virtualbong, et al.) my drop is significantly lower - 1.6/1.6 or thereabouts. To get a balanced drop between front and rear, rather than a rake, I had the shop use the middle spring perch on the front shocks and move up one in the back to get it slightly lower (the Neuspeed Konis have five perches instead of the normal three).
Here is the result:
![](http://www.sincerussia.com/myelin/tsx/neuspeed1.jpg)
![](http://www.sincerussia.com/myelin/tsx/neuspeed2.jpg)
![](http://www.sincerussia.com/myelin/tsx/neuspeed3.jpg)
![](http://www.sincerussia.com/myelin/tsx/neuspeed4.jpg)
![](http://www.sincerussia.com/myelin/tsx/neuspeed5.jpg)
![](http://www.sincerussia.com/myelin/tsx/neuspeed6.jpg)
![](http://www.sincerussia.com/myelin/tsx/neuspeed7.jpg)
And of course the closeups of my wheel gap at the moment:
Front:
![](http://www.sincerussia.com/myelin/tsx/front1.jpg)
![](http://www.sincerussia.com/myelin/tsx/frontgap1.jpg)
![](http://www.sincerussia.com/myelin/tsx/frontgap2.jpg)
Rear:
![](http://www.sincerussia.com/myelin/tsx/rear1.jpg)
![](http://www.sincerussia.com/myelin/tsx/reargap1.jpg)
![](http://www.sincerussia.com/myelin/tsx/reargap2.jpg)
Conclusions:
These springs are noticeably stiffer than stock, but not by much. I actually got a much harsher ride when I switched from stock tires to my 235/40/18s. This suspension made almost no difference comparably. I was worried that I would lose so much comfort that I'd be pushed out of the sport-luxury category but this has not been the case.
I have had a few instances of rubbing though. Not in the range of motion of the steering (that clears fine) but if I hit one of those invisible-until-ten-feet-away frost heaves that we have to live with on our asstastic New England roads. The wheel gap isn't much, and I'm beginning to wonder if it's too little for the rate of these springs. Or it could be more a result of my tire width (235) instead. Feel free to offer any thoughts on this matter as I'm sure you will have some. Only two things I can think of are slightly narrower tires or perhaps raising the drop a bit to the next-lowest spring perch on all four corners. In any case, it doesn't occur frequently or harshly enough for me to make it a priority, so I'm not rushed to resolve it.
Also, I installed my Progress rear swaybar at the same time (on the stiffest setting). Body roll is almost completely done away with, and I haven't noticed any understeer.
Onramps are a blast now!
Here is the result:
Front:
Rear:
Conclusions:
Luke 1:37
Looks awesome Ryland! Can't wait to see everything in person. I'm going to install my Greddy Evo2 Catback tonight. Just got back from PA (5+ hour drive), but I really want to put it on so it goes on tonight. Hope everything goes well
Drives With Hands
Originally Posted by virtualbong
Looks awesome Ryland! Can't wait to see everything in person. I'm going to install my Greddy Evo2 Catback tonight. Just got back from PA (5+ hour drive), but I really want to put it on so it goes on tonight. Hope everything goes well ![Wish](https://acurazine.com/forums/images/smilies/wish.gif)
I also just realized:
![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
Luke 1:37
Sweet dude. Hey, how does this compare to your drop? You run 225/40/18s right? Do you get the occasional squeak when you hit a frost heave from the front tires hitting the fenderwell lip? I'm trying to figure out if my tires are a hair too wide or my car was somehow lowered more than yours was.
That was supposed to say oversteer.![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
rmpage,
Your car looks great. Are you getting rubbing in the front or rear or both? What offset are you running on your rims? I'm running 235-40-18s on 18x8 +51 offset rims and do not have any rubbing issues at all. I'm lowered on Comptech springs w/ Neuspeed Konis. It's a bit higher than where you are now (1.5 finger gap in front and a tight 2 finger gap in rear). Have you done your alignment yet? Running less negative camber can also increase the likelihood of tire rub on the wheel well.
Drives With Hands
Originally Posted by AlterZgo
rmpage,
Engineer
looks great man... cant wait to see it at the meet in a few weeks...
Drives With Hands
Originally Posted by DietCoke
You should get the OEM body kit, it would make the exhaust look better. Everything looks great though, I love Arctic Blue...
That looks very very nice.
My guess would be that the tire size is the culprit of your rubbing vs VB or AlterZgo.....
Your tires are essentially the same diameter as stock but stick out .67" further. VB's tires are like .33" smaller diameter which probably gives him the extra clearance with the same drop. AlterZgo has the same size tires as you and similar offset, but isn't dropped quite as much.
I'm down a little more than all you guys and have yet to rub with 225/45/17, which is even smaller than VBs tires. Wheel is 17x7 45 offset.......
Professional Newbie
Your drop looks exactly like mine. I haven't rubbed once, so I'm thinking that its your tires that are making the difference.
Drives With Hands
Originally Posted by dzuy
high flow cat?
someone makes one for our car???
Originally Posted by madmanmax3000
I have 215's on my rims (or maybe its 225...?), is that what you have? No rubbing should happen with that, right?
Just in front, and the offset is +48mm. It rubbed frequently on the 10 minute trip to the alignment shop but aligning fixed a lot of that. Still more than I'd like though.
vwong is running 19x8 +40 offset 235-35-19s on his super slammed TSX and, while he definitely rubs, the front tire tucks under the wheel well. Your +48 should be fine even w/ 235-40-18s.
You can try turning the front shock adjustment knob to full soft (opposite direction of firm on the knob). This will fully soften the rebound, but will fully stiffen the compression which should prevent the car from coming down as much when you hit a bump.
You can also raise the front 1/4" so that the front and rear wheel well gap would be equal at about 1 1/2 finger gaps. Car will still look nice and low.
Today, I'm going to drop my rear spring perch 1/4" so I'm at about 1.5 finger gap all around.
Drives With Hands
Great advice as always, AlterZgo. I'll try adjusting the front damping since I should be able to do it myself. If that doesn't work I'll probably end up raising the front by going one perch lower from the middle of the shock.
Different brands of tires with the same advertised width don't always have the same actual width. Additionally, the width of the rims can affect the sectional width of the tires. http://www.tirerack.com/tires/tirete...p#sectionwidth
I have tested ES100 235 tires for about a month and ended up replacing them with 225 due to clearance problem with the drop that I have. It wasn't a huge issue, but I can't stand even the slightest rubbing sound.
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Luke 1:37
Kinda off topic, but since you've been talking about using the shocks to adjust the height, I think I set the spring perch incorrectly. I wanted to lower the rear .25", but I think I may of raised it instead. I'm pretty sure I set the rear spring perch one setting down from the neutral spot. So that means that I raised it .25" right? Shit.
......to raise the front 1/4" you want to go UP one groove from where you are now.....
Drives With Hands
Oops...by one lower I meant as it is installed in the car. That should make the shock sit higher out of the spring, resulting in a higher stance, right?
Imagine that you are looking at the side of your car with the wheel taken off. You see the grooves in the body of the shock. The corresponding positions will be as follows:
![](http://img170.echo.cx/img170/8039/koniheightadjustments0ta.jpg)
Remember that moving the spring perch up or down does not compress the spring. It simply raises the position of the spring up or down which will result in a corresponding increase or decrease in ride height.
Another thing - the shock does not determine the position of the car. Whether the shock itself sits higher or lower has no effect whatsoever on the height of the car. The weight of your car is fully supported by the 4 springs. That is why raising or lowering the spring perch will raise or lower your car.
Matell
It is a universal model. I used a Carsound Magnaflow 54306. I'm going to post a thread about it once I can get a dyno comparison and some better pictures, but suffice to say, it added at least as much power as my CAI did with very little additional noise. No problems with passing emissions either.
Drives With Hands
Originally Posted by Matell
A little off topic and I can't wait to see your post on the Cat, but where did your fabricator (or you) install the original mid-mount O2 sensor or are you using an O2 simulator? I know JTso's also working on a cat swap out as a project, as am I.
Luke 1:37
Originally Posted by jmathew34
rmpage, do you notice any noises from the suspension setup? i.e. what some members are experiencing with coil-overs?
What about you rmpage?
Drives With Hands
Nothing noticeable yet. I listened intently on the first few drives - windows down, going slower, radio off, and didn't hear anything.
You shouldn't hear any noises at all with Koni's; they're basically as quiet as the stock struts. As long as everything is lined up and installed correctly, it will be noise free.
With the Tein FLEXes, I can hear a slight compression of the struts, but I don't want to overstate it; I would have to be windows open, radio off and then hit a small bump, and even then it's barely audible-no one driving in my car has ever noticed it. It's just the extreme pressures of the strut at work. Any noise louder than that would have to fall under the category of incorrect assembly/installation......
TLDude876
12-28-2016 03:18 PM
Zonian22
11-14-2015 01:20 PM
k6biv
09-10-2015 06:37 PM
