coilovers on!!
2004 NBP/ebony AT
coilovers on!!
WooHoo i love these things, it handles SOOOO much better and didnt hurt the ride much, i havent had a chance to play with the settings yet but will, also what dampening setting does it come with?By the way i have a one or less finger gap on all fours so its LOW! COMMENTS PLEASE
on monday the 27th its going back up there to get the swaybar,camber kit,an easy way to adjust dampening is going to be made, an alinement, and subs are getting put in so stay tuned!!
NICE... prepare yourself for the camber and alignment. Right now the back end is tight on solid group and probably loose over bumps. Once aligned it will feel less grippy, but you soon learn how much more stable it is. I suggest -1.5 on the rear.
2004 NBP/ebony AT
o yea i new that, but im going to keep it as low as i can right now becuase the OEM kit isnt goin to be on my car for atleast 6 months. So ur saying that once i get it cambered and alined it will not handle as good? and when i get my swaybar on ill still be able to tell a difference rite? and what about the dampening setting from the factory? what are they? thanks for the comments guys!!
I can comment on the handling after camber kit and alignment. Basically you have extreme camber on the rear wheels and probably a fair amount of toe too. This will make the rear end very grippy in corners, but it'll bounce around on bumps and be very sensitive to uneven road. Once the alignment comes back into spec, you won't have that extreme grippy on the rear... oh, it'll still handle great, but you'll notice the rear end be a little more loose than pre camber and alignment.
Originally Posted by kyotousa
hey i still don't understand what does it do.....adjust the negative set from the factory?
i c thx...my friend told me if i lower less than 1.5 inch i don't need to worry
but i saw i thread here say there's advantage to buy camber anyway, it'll make your tire last longer or something.....
anyway i'll read that info when i get a chance thx
Received 3,858 Likes
7th Gear
camber problem
I just had wheel alignment done and to my surprise the rear left was less than -0.5 deg while the right was -2.5!! This result was with the Koni + pro kit combo installed. Anyone knows how this is possible? No damages were found at the axles at all. Should I just get 1 piece of camber kit instead of a pair? Thanks guys
Bye TSX, hello domestic?
In any event, still better to get the camber kit.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
4drviper
09-23-2015 07:42 PM
