White LED For my Boost Gauge
Rep'n Taxbrain.com
Hey guys,
Just put a boost gauge in last weekend. It came with an incondescent bulb so the lighting is more yellowish than white to match our gauges. I'm looking for a white LED bulb to replace the one I currently have. Do you guys have any suggestions on where I should get it?
The specs on the incandescent bulb are:
161 wedge based bulb, 12 volt, T 3-1/4, 1 Candle Power
Here's a link to it:
http://www.sw-performance.com/index....tails&p=114896
The first question I have is what does the T 3 1/4 refer to? Is this the size of the base?
Would this bulb work for me?
http://cgi.ebay.com/194-168-161-Oval...QQcmdZViewItem
The size on that bulb says T10 though, so I'm guessing it won't work. I just want confirmation on this. I'm a newbie to LEDs.
Thanks in advance
Thanks in advance
Rep'n Taxbrain.com
Hey J! I don't have any pics of it in the car right now. I ended up mounting it to the very left of the gauge cluster. It partially covers the temp gauge but I can still see it if I lean forward. It's not big deal once I get the engine warmed up though, I barely look at it after that.
I'd definitely recommend getting the boost gauge. It actually helps to be able to see when you're in vacuum and when you're in boost. I can lighten up on the throttle just enough when i want accelerate but don't wanna go into boost. I think it's going to help me maximize my gas mileage.
Here's a pic:
Here's a pic:
Kenny, I found these on superbrightleds.com
http://www.superbrightleds.com/mini-wedge.html
Those on your ebay site look good too.
Received 3,656 Likes
stewart warner makes a led chameleon gauge kit for there gauges. that is what I have in my stewart warner gauges and it matches stock pretty well.
Rep'n Taxbrain.com
The ones in this Ebay link says "T10"
Do you know if that will still fit even though my current bulb is T 3 1/4?
Rep'n Taxbrain.com
Originally Posted by rmpage
Where are you guys getting your Stewart Warners? I need to buy a bunch of gauges in the next couple of weeks.
I do not have any right now but if you want to wait I will take some next weekend while I am home for a show.
Drives With Hands
Originally Posted by Tsx536
I got my gauges from SummitRacing.com. Do you have the Turbo system installed in the other car yet?
Also thanks for the link. Too bad Stewart Warner doesn't make a wideband. They have everything else I need. Hmm...
Drives With Hands
Originally Posted by xizor
i have autometer cobalt's in my vette and the blue would probably compliment the TSX dash well, if you want to spend the $$
Cobalts do look nice though.
The Sport Comp II series looks almost exactly like our instrumentation.
