UR pulley install price? and Topspeed pipe diameter?
I had two quick questions
One- normal estimate for installation of Unorthodox 3-piece pulley set with new belt
Two- Top speed header diameter vs oem? I went to a shop today and the guy noticed a smaller diameter pipe before the flex pipe, whereas the oem is a larger diameter? can anyone explain how this would be beneficial to switch Topspeed header vs the oem exhaust manifold?
Thanks I recieved an estimate for $250 for the install of the pulleys and the new belt. I was like WTF??
If I had a damn impact I would have had this done by now. Is this install easily done without? I read JTso's post and have reviewed things, but thought it would be easiest with an impact. Maybe I will just try to tackle it this weekend, I already pulled off my Ingalls ETD so I can get at all of the pullies
![what](https://acurazine.com/forums/images/smilies/what.gif)
CL9 ABP
If you can lift the car and get into that one crankshaft fully while the car is lifted then thats mainly your only problem.
I tried it myself and lacked many powerful tools and a properlift i got nowhere.
Pssh, I was quoted $650 for the pulleys install, no joke. You may have to shop that one around a bit. I ended up DIY'ing it, but it was very difficult and I had to buy a special tool to do it... not for the faint of heart!
I've got one of these bad boys: http://www.moroso.com/catalog/catego...?CatCode=27115
I'd only spring for it if you plan on using it more than once as I have. For an AT however, you need it or something similar, as you can't put the car in gear to brake it.
Former Sponsor
Hehe, if anyone wants one:
http://www.heeltoeauto.com/Moroso-Cr...s-pr-2452.html
$650 is nuts man.
$250, you COULD buy a compressor and impact, but not likely have enough power to remove the pulley.
johnpancakes014
04-08-2016 06:47 AM
InFaMouSLink
10-27-2015 06:51 PM
IIDXholic
10-08-2015 07:53 AM
