Type S Sway bar clears Greddy Evo2?
Old Jan 27, 2012 | 10:15 AM
supafamous's Avatar
Hi,
Planning to put a Greddy Evo2 on my car and was thinking of putting a TL Type S sway bar on as well but was wondering if anyone knows if the two play nice with each other (don't get in each others way).
Anyone with experience with this?
thanks,
Eric
Old Jan 27, 2012 | 10:18 AM
no clearance issues with your stock RSB?
how thick is the stock TSX bar?
the tl-s RSB is 20mm, i believe.
Old Jan 27, 2012 | 10:32 AM
supafamous's Avatar
Yeah, TL-S is 20mm. The shape is different than the stock one though (e.g. you have to bend an exhaust hanger to fit it) and I've heard some sway bars don't play nice with some exhausts (comptech RSB for example).
Here's an install guide with pics of the two bars: http://tsxcore.blogspot.com/2011/03/...bar-on-04.html
Old Jan 27, 2012 | 10:38 AM
When I visit that blog site, I can see it for all of 2 secs. then it goes blank, like its trying to load something.
will have a look at home.
I do have a stock TL 6MT RSB sitting in my garage, as I upgraded to the progress RSB.
I believe the 6MT bar is 20mm as well.
Old Jan 27, 2012 | 09:03 PM
r3devi7's Avatar
ReDevil
Im my forum travels, LOL, I keep interesting info in a notepad file... maybe you guys can help me finish it;
TLS 6MT Front Sway: 27.2mm Solid
TL Base Front Sway: 27.2mm Hollow
TLS 6MT Rear Sway: 20mm
TL Base Rear Sway: 17mm
TSX Base Rear: 15mm
Old Jan 30, 2012 | 12:33 PM
mball's Avatar
Will a TLS rear sway bar fit on a TSX with a stock exhaust without interference?
Does anyone know the part number of the TLS rear sway bar?
Old Jan 30, 2012 | 03:07 PM
supafamous's Avatar
It clears the stock exhaust just fine - just have to bend the exhaust hanger that's used for single exhausts out of the way.
Parts (and prices) are:
  • 1x '08 TLS RSB p/n 52300-SEP-A11 $34
  • 2x '08 TLS RSB Bushings p/n 52306-SEP-A11 $1.14
  • 2x '08 TLS RSB Bushing Holder p/n 52308-S3M-A00 $0.85
  • 4x '08 TLS RSB Bushing Holder Bolt p/n 93402-08016-08 $0.68
  • 2x Self-locking nut (endlink-RSB nut) p/n 90212-SA5-003 $0.38
Old Jan 31, 2012 | 12:38 PM
mball's Avatar
That is a fairly cheap upgrade. Are the bushing holder bolts necessary or can the TSX bolts be reused?
Can the exhaust hangar be bent with common tools? My TSX has the factory dual exhausts. Will I still need to bent the hangar?
Old Jan 31, 2012 | 12:55 PM
supafamous's Avatar
Not sure about the TSX bolts.
The exhaust hanger can be bent easily according to those who have done it - it's like a 5-7mm thick piece of steel. Couple whacks with a hammer should do it. You could also cut it off if you have a hacksaw (I will probably do that).
Google it and you'll find install instructions, pretty easy stuff from what I can tell.
Old Feb 6, 2012 | 10:57 AM
mball's Avatar
Does anyone know the cheapest place to get these parts? My local dealer wanted $48 for the bar and about the same as above for the other components. I found the bar online for $35 but, shipping was $20.
marcelft
Jul 10, 2018 06:17 PM
drone619
Jan 26, 2016 07:09 PM
MonkeyTrucker
Sep 21, 2015 06:15 PM
k6biv
Sep 10, 2015 06:37 PM
frostwhiteh22at
Sep 6, 2015 12:48 PM
