TopSpeed and OBX vs DC
Old Feb 9, 2008 | 05:04 PM
feuss2's Avatar
Cool TopSpeed and OBX vs DC
Are TopSpeed and OBX headers both just stainless copies of the DC? What are the major differences between them besides the stainless vs coated mild steel...
Old Feb 9, 2008 | 05:34 PM
Reach's Avatar
The OBX one doesn't even fit. Its the most shameful knockoff ever, do not give that company any serious consideration on any of their products.
Old Feb 10, 2008 | 09:19 AM
feuss2's Avatar
TopSpeed OK?
Old Feb 10, 2008 | 10:45 AM
Reach's Avatar
Yes, Topspeed is OK. It is fine to use as it comes; but one upgrade for it I suggest is to replace the flex pipe it comes with before you install it. It doesn't fail like the DC one does, but it is a cheap single wall design similar to DC's. It produces a hollow sound that you can get rid of for a $20 flex pipe upgrade plus the cost of the re-weld.
Old Feb 10, 2008 | 10:46 AM
04-6mt-atx's Avatar
my Topspeed header has be fine, especially for the price.
Old Feb 11, 2008 | 11:13 AM
JdmStyle's Avatar
I got myself an OBX header../ and worked fine.. fitment wasn't a problem.. the only problem was the flex pipe as in other headers I have had on other cars.. does not have a liner in it.. therefore producing a sonic whistle when accelerating.. sucks.. cut it out and replace with a flex with a liner in it..
Old Feb 12, 2008 | 05:38 PM
feuss2's Avatar
Any reason why a TopSpeed with a flexpipe upgrade would not be as good as a DC or Comptech?
Old Feb 12, 2008 | 06:07 PM
jlukja's Avatar
^^ provided their manufacturing process has good quality control, no reason it shouldn't be as good as DC, its a DC knockoff to begin with. Comptech's design is slightly different.
Old Feb 12, 2008 | 06:14 PM
feuss2's Avatar
Do you have more info on the differences?
Old Feb 13, 2008 | 06:21 AM
vasu's Avatar
slightly off topic, but are there any tsx headers out there that don't require fixing/modding before installation?
Old Feb 13, 2008 | 07:43 AM
GTSX-05's Avatar
ASM 3G TL Type-S
I believe DC and Topspeed have firm fitment, they do not require modification on initial installation but its recommended since your probably going to run into problems sooner or later. I am speaking about the re-welding of the pipes.
Old Feb 13, 2008 | 08:02 AM
vasu's Avatar
Yeah that's what I meant. does anyone make one that doesn't require re-welding down the road?
Old Feb 13, 2008 | 08:14 AM
feuss2's Avatar
Comptech for about $550... Although if you have an AT there may be a rattle issue. Wonder if that could be resolved by a difference flex pipe to. I think the answer is NO!
Old Feb 13, 2008 | 11:24 AM
raheel616's Avatar
i have topspeed no problem except a lot of hissing
Old Feb 13, 2008 | 02:44 PM
jlukja's Avatar
Comptech is stainless steel just like Topspeed. DC is ceramic coated mild steel.
Topspeed and DC are both 4-2-1 design (Topspeed being a copy of DC Sports). Comptech is a 4-1 design. The performace characteristics will be slightly different due to the differences in the design but overall you should see about 10hp difference for both.
Old Nov 23, 2008 | 03:15 PM
valeratj's Avatar
Unregistered User
I just ordered topspeed. Does anybody know if it removes cat ?
Old Nov 23, 2008 | 03:18 PM
godfather2's Avatar
Time to Climb
^ does not remove cat
Old Nov 24, 2008 | 02:44 PM
valeratj's Avatar
Unregistered User
Thanx. Time to order a test pipe !
Old Jun 20, 2011 | 06:44 PM
jrb898's Avatar
6th Gear
is there a difference in performance between ceramic and stainless headers?
clc
Mar 19, 2005 09:00 AM
AccordR
Mar 3, 2005 05:34 PM
