For those that have modded their NAVI....
to play dvd's.... what kind of audio input are u running? I'm using mine on fm but its too quite and its sounds shitty
Originally Posted by Tsx536
You should hardwire it with a SNHOND3 or Blitzsafe.
Sounds much better that way. If it's still not loud enough, you can use a line driver to amplify the sound.
I used a 4 pole relay wired into the xm harness on my '05. I can toggle between the xm feed or the aux RCA's soldered onto the relay. Sounds CD quality with no noise. Costs about $8 in parts and about 1 hour of your time if you can solder. I had pics on here some where. If not, buy the blitzsafe that most people are using.
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
so you're NOT using any of those aftermarket AUX input adaptor ?
hi all, i'm shiek from AZ. i was thinkin' about flat out just buying a dvd player and installing it below my radio. i have the navi as well. i figured it would be a few hundred dollars. but now i see yall have modified the navi to play dvds but with not the best quality. which do u think is better taking in acct the quality vs price?
InFaMouSLink
10-27-2015 06:52 PM
lanechanger
10-13-2015 10:56 AM
