Short Ram VS CAI
Pearl White In E-Town
Short Ram VS CAI
Can someone help me. I'm trying to decide whether to go with a short ram or a CAI. Which has the better performance gains, easier installation etc... Also if I go with a CAI, Injen or K&N or Icebox??
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
SRI = (slightly) easier to install
Icebox = smaller gains than SRI, but REALLY easy install and cheaper (I think...). Also, Icebox is not a CAI in the traditional sense since it still has a "box".
Get an Injen or K&N. Lots of us (me) have Injen and are very happy with it.
A-spec Arctic Blue
As far as installation, all setups will require you to remove the stock resonator. I guess for the Short Ram, you don't necessarily have to but it is added weight for parts that are not used anymore. If you have the right tools, the install shouldn't take more than 1 - 2 hours. The K&N install guide is probably the easiest to follow and the removal of the front left tire is probably the best way to go.
How real is the threat of hydrolocking with a CAI. (It's snowy here for at least 5 months) I am correct that you don't have to worry about that with an icebox?
Injen can be run in CAI or SR mode so thats your best bet. Not sure about the K&N. I'm running in CAI right now but plan to change to SR for the winter when I put on the snow tires. The install/changeover is not all that difficult.
I don't really see how snow could hydrolock you considering the structure of splashguarding we have around that area. I'm pretty sure it's difficult to get snow ON the filter, period.
Edit: One thing is for sure, though: Hydrolock = death to an engine this size (or larger). So I won't fault you for erring on the side of caution.
Faster, please.
I was also concerned about the adverse effects of a CAI including hydro-locking (see thread "long term effects/risks of CAI). I went ahead and had the injen installed a couple weeks ago and love it.
In terms of hydro-lock the mechanic who installed mine (an actual race team mechanic) said you would need to either submerge the filter or throw several gallons of water onto it in order to do so. Furthermore, since the engine is essentially a vacuum in regards to sucking air through said filter if you are unsure of the amount of water you're about to drive through take your foot off the gas to close the throttle and essentially turn off the vacuum effect. Basically just don't drive through a foot of water.
As far as snow I also don't see how that could adversely affect the intake. There doesn't seem to be any possible physical way for snow to be sucked through the filter. I do wonder about the effects of salt water hitting the filter (i.e. after the snow has melted and mixed with the road salt). I wonder if that might shorten the life of the filter or require cleaning. In any case I'll probably put the K&N Drycharger over the filter for the winter months just to be safe.
Sorry I write such long posts.
A-spec Arctic Blue
Faster, please.
BTW, today it rained pretty heavily here all day. I drove through at least one large puddle and no problems. Like I and many others have said if you don't drive through a flood you should be cool.
And the thing sounds BADASS!!!
AcuraKidd
09-25-2015 11:18 PM
