Service loop for rpm and timing light hookup
Since the TSX doesn't have sparkplug wires. Some of you may wonder where to hook up for timing light or rpm for the dyno.
Service loop
Here is the service loop (grey color) right behind the valve cover. It's attached to the wire harness with two zip ties and a piece of blue tape. You have to remove the blue tape and zip ties in order to connect the inductive pickup.
![](http://www.tsobad.com/jtso/Images/Service%20loop/Service%20loop.JPG)
Inductive hookup
![](http://www.tsobad.com/jtso/Images/Service%20loop/inductive%20pickup.JPG)
RPM at idle
The tach in the dash is amazingly accurate. It matches to the instrument perfectly. I noticed how accurate it was on the dyno. Now it's verified. Idle spec = 750 +/- 50 (MT)
Service loop
Inductive hookup
RPM at idle
mada51589
05-03-2022 08:54 PM
asahrts
09-04-2015 05:55 PM
