RSX-S tranny on a TSX - pros and cons?
I have a 2004 TSX and it doesnt go into any gear but 5th so I think the shift forks fell out of place or something along those lines so I guess I have to change it. i have an rsx-s tranny sitting here in mint condition and I was going to ask if ther are any pros can cons of using the rsx-s tranny. Is the gearing ratios the same?
any help is appreciated.
Polar Chicken
TSX:
st Gear 3.27
2nd Gear 1.88
3rd Gear 1.36
4th Gear 1.03
5th Gear 0.83
6th Gear 0.66
RSX:
1st Gear 3.27
2nd Gear 1.88
3rd Gear 1.21
4th Gear 0.92
5th Gear 0.92
st Gear 3.27
2nd Gear 1.88
3rd Gear 1.36
4th Gear 1.03
5th Gear 0.83
6th Gear 0.66
RSX:
1st Gear 3.27
2nd Gear 1.88
3rd Gear 1.21
4th Gear 0.92
5th Gear 0.92
I think black_6spd is the guy to ask about this. I think he swapped a couple of gears, but not all of them. He loves it, BTW.
Originally Posted by Zasker1
TSX:
st Gear 3.27
2nd Gear 1.88
3rd Gear 1.36
4th Gear 1.03
5th Gear 0.83
6th Gear 0.66
RSX:
1st Gear 3.27
2nd Gear 1.88
3rd Gear 1.21
4th Gear 0.92
5th Gear 0.92
st Gear 3.27
2nd Gear 1.88
3rd Gear 1.36
4th Gear 1.03
5th Gear 0.83
6th Gear 0.66
RSX:
1st Gear 3.27
2nd Gear 1.88
3rd Gear 1.21
4th Gear 0.92
5th Gear 0.92
TSX:
st Gear 3.27
2nd Gear 1.88
3rd Gear 1.36
4th Gear 1.03
5th Gear 0.83
6th Gear 0.66
RSX:
1st Gear 3.27
2nd Gear 1.88
3rd Gear 1.21
4th Gear 0.92
5th Gear 0.92
st Gear 3.27
2nd Gear 1.88
3rd Gear 1.36
4th Gear 1.03
5th Gear 0.83
6th Gear 0.66
RSX:
1st Gear 3.27
2nd Gear 1.88
3rd Gear 1.21
4th Gear 0.92
5th Gear 0.92
RSX-S
1st gear 3.266
2nd gear 2.13
3rd gear 1.517
4th gear 1.147
5th gear 0.921
6th gear 0.738
final drive 4.389
the thing is you can´t use the rsx-s trans housing it´s different from the tsx´s but he can and should swap gears and use the rsx-s 1-5gears and the tsx 6th and final drive.
As far as using the rsx-s housing and gears, I believe you might run into some issues with the connectors. Keep in mind that the folks running a K24A2 with an RSX-S tranny are using them in swapped Ep's and DC's, mostly due to clearance issues. I've yet to encounter anyone using the RSX tranny on a TSX chassis.
What year is your rsx tranny? If it's pre-05, you'll likely encounter the notorious 2nd gear grind issue. Also, you might want to consider an LSD while the tranny is down.
If you decide to swap the gears out, keep in mind that your reliability will be nowhere near stock and your speedo will be off:
https://acurazine.com/forums/showthread.php?t=34389
To me, it's still worth the risk.
emailnatec
29
09-28-2018 04:27 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
AcuraKidd
09-25-2015 11:18 PM
