View Poll Results: Which rotors would you recommend/have?
Racing Brake UP
35
32.11%
Powerslot
22
20.18%
Rotora
11.01%
Brembo Blanks
40
36.70%
Voters: 109. You may not vote on this poll
Rotors Poll: Racing Brake, Powerslot, Rotora, or Brembo Blank
Old 03-16-2006, 01:41 PM
Rep'n Taxbrain.com
Tsx536's Avatar
The next upgrade I'm going to do will be my brakes. I've already decided on Hawk HPS pads based on feedback from other threads. I did a search, but I still don't know what rotors I want to get.
Which rotor would you guys recommend?
What is the life span of a typical aftermarket rotor?
Any pros/cons of each brand?
Old 03-16-2006, 01:56 PM
CCColtsicehockey's Avatar
Received 3,791 Likes on 2,555 Posts
I vote racing brake.
If I would have seen them before I would have bought them.
Also check out this company as I have heard good things about them too. http://www.dba.com.au
Old 03-16-2006, 01:59 PM
Benz_05_TSX's Avatar
Mugne rotors w/ Mugen racing pads :troutslap
Old 03-16-2006, 02:20 PM
JoeC1982's Avatar
I like the fact that i can get powerslots front and rear even though the rear is more for looks. can you use racing brakes up front and powerslots in the rear with no ill effects?
voted for RB's btw
Bye TSX, hello domestic?
xizor's Avatar
I have a set of Racing Brake fronts and power slot rears I'll be installing w/ Hawk pads whenever it gets warm
Old 03-16-2006, 02:44 PM
Former Sponsor
Excelerate's Avatar
ROTORA
Old 03-16-2006, 04:11 PM
Vegito's Avatar
I'll prob never use Powerslots again.. had them for my av6 on 4 corners.. couldn't tell.. upgraded the brake lines.. was a bit better.
Old 03-16-2006, 04:31 PM
Rep'n Taxbrain.com
Tsx536's Avatar
Thanks for the input so far guys. Right now I'm leaning towards either the Racing Brake UP or Brembo Blanks.
Cost wise the Racing Brakes cost almost twice as much as the Brembo blanks though. I'm trying to justify that cost.
Do you think the Racing Brake UPs will easily outlast the brembo blanks? I'm hoping I can get 80K out of the of the RB UPs. I do mostly highway driving. How realistic does this sound to you guys?
The main thing I'm concerned about is warping. Are the Brembo also designed to be resistent to warping?
Old 03-16-2006, 05:03 PM
B A N N E D
925tsx's Avatar
well put it this way
i put the rb rotors and hawk pads up front at 20k.
last week i took the car in for rear pads and rotors at 65k. while i was there, i had them check the fronts.
still alot of meat on the pads, and rotors are within spec..no warping, no rust, nothing.
i can honestly say the racing brake rotors are the best quality ive ever seen.
and i drive like a maniac.
Old 03-16-2006, 05:08 PM
Rep'n Taxbrain.com
Tsx536's Avatar
Thanks for the response. It definitely helps
Are the RB rotors heavier than the OEM rotors?
Did you notice any difference in acceleration after they were installed?
Old 03-16-2006, 06:05 PM
drkangel348's Avatar
I have Brembo Blanks with Hawk HPS pads. No complaints, and it definitely brakes better.
CarbonGreyPearlEbony
TSX420J's Avatar
Im having this same problem... Now I think im gonna get r/b's. 112.00 ea. is a lot less than what I expected to pay for good quality rotors..
Old 03-16-2006, 06:08 PM
tuan209's Avatar
I would probably get the G3000 blank rotors at cobaltfriction.com. at 70 dollars for the front rotors and 40 for the rears, i think its a hard value to beat.
Old 03-16-2006, 06:35 PM
TSX420J's Avatar
Just saw rotora drilled and slotted for 90something dollars @ horsepowerfreaks.com
Old 03-16-2006, 06:42 PM
TSX420J's Avatar
and rotora slotted for 86.00 ea
Old 03-16-2006, 06:52 PM
drkabe's Avatar
[QUOTE=Tsx536]Thanks for the input so far guys. Right now I'm leaning towards either the Racing Brake UP or Brembo Blanks.
The main thing I'm concerned about is warping. Are the Brembo also designed to be resistent to warping?[/QU
im also in the same boat....i want racing brake front and power slots rear..but where can i get the racing brakes from?
Old 03-16-2006, 08:52 PM
TSX420J's Avatar
http://www.racingbrake.com/ACURA_TSX_s/111.htm
Old 03-16-2006, 11:00 PM
cor6bro's Avatar
I have Brembo Rotor Blanks and Hawk Performance Ceramic pads up front. Generally I'm pleased. Performance wise, this setup is much better than stock. Two months already and no hint of the dreaded TSX steering wheel shimmy. Slightly less initial grab than stock when cold (North East winter), but good stopping power overall, especially when warmed. I've gotten on them pretty hard a couple of times so from that I'd say that the combo is a tad better than stock in terms of overall stopping performance. The blanks are rock solid. - No performance vices...just...I was a little disappointed that the rotor isn't protected against rust, especially the hat area. After all it's just a blank, right. I believe the stock rotors had some type of coating or something in the area of the hat (center). Minor gripe I know, but it could be a problem if you have upgraded wheels.
Good luck w/ your choice
Old 03-16-2006, 11:40 PM
iVTEC no koe
HoRRo's Avatar
Sponsored Sale:
https://acurazine.com/forums/sponsored-sales-group-buys-10/racingbrake-rotors-available-here-now-316102/
Old 03-16-2006, 11:56 PM
Alin10123's Avatar
You aren't supposed to be able to tell that you've upgraded your rotors. Putting in the slots just helps dissipate the heat better.
Old 03-17-2006, 07:55 AM
Drives With Hands
rmpage's Avatar
Aftermarket rotors tend to have a higher thermal mass than OE rotors so they soak up heat better, which means they brake more consistently each time and don't fade as easily when they get hot.
Not sure if the Powerslot weights are that different though.
Old 03-17-2006, 09:03 AM
アコードタイプSとくれば、喜びもひとし お。思わず投
lito's Avatar
yah you don't have Mugen rotors in the list so I wont vote
Old 03-17-2006, 01:41 PM
Rep'n Taxbrain.com
Tsx536's Avatar
Are you changing your rotors when you do you brake job?
If so, what brand are you going with?
Old 03-17-2006, 01:42 PM
Rep'n Taxbrain.com
Tsx536's Avatar
Haha...yeah. Sorry no Mugen rotors for me. I don't know how much they are, but I'm guessing they are probably quite a bit more expensive then the ones I listed.
Old 03-17-2006, 04:40 PM
Drives With Hands
rmpage's Avatar
Racingbrake on the fronts, Power Slot on the rears. I don't care about the rears, they only do a little bit of the stopping work anyway (something like 20% on the TSX, I think).
Old 03-17-2006, 05:58 PM
GSGOMEZ's Avatar
What about Sp performance? Check it out: https://acurazine.com/forums/showthread.php?t=29356 I like those style of rotor brake.
Old 03-17-2006, 06:26 PM
Rep'n Taxbrain.com
Tsx536's Avatar
Those look kind of interesting. Has anyone had experience or heard of anyone with these?
Old 03-18-2006, 12:02 PM
bbbradley's Avatar
You have it backwards, the slots hurt the heat dissipation ability. You want thermal mass, removing material doesn't help, it hurts.
Old 03-18-2006, 12:05 PM
Go with the Racing Brakes. I would want something that is supposed to be better than average brembo blanks if I had a supercharger.
Old 03-18-2006, 03:47 PM
^ ya man...if you have the dough to invest in a supercharger, invest in something with more stopping power, you will need it!
Old 03-19-2006, 01:54 PM
TSX420J's Avatar
im not knocking you but its funny when people say invest because no matter how much $$$ people put into their cars the price will never go up and people will never profit from doing mods to their cars. the value just goes down more and more...only if it was a classic, antique, special edition ,very rare or if the car had zero miles on it and you mod it all up to sell is the only way i can see it as a true
investment... I say the same thing but its really like an investment for happiness,
like i just wasted all this money on my car i will never get anything for it but it makes me happy as hell to have a sick ride...
Old 03-19-2006, 02:14 PM
ok i dont think he was talking about invest as like you make a normal investment he just ment buy something with more breaking power since he had added more power to his car.
Old 03-19-2006, 04:41 PM
and by invest, like you said, investing can have multiple definition. Usually people think investment will involve in making a profit. Profit is defined as a gain. Thus, if we tie back everything together, what are you gaining from a supercharger and more stopping power?? Happiness, fun, utils (for economists). We are young, we shouldn't only invest in things that will gain material profit/gain. We should invest in something that will give us a gain in happiness, thus = our car mods. I mean, if all you care is investing in things that will result in a profit of money, then why buy nice clothes? mods of cars? eat nice food? It's just a preception~
Old 03-20-2006, 04:47 AM
B A N N E D
925tsx's Avatar
Yes they are definately heavier, but they are fawkin SOLID. I didnt notice any decrease in acceleration at all. buy them!
if u want a discount, pm me ill see what i can do
Old 03-25-2006, 01:50 PM
shitbox's Avatar
So which rotors are more perferable for salty winters? it snows alot in toronto and they pour salt like crazy. are there any rust-proof rotors?
Old 03-25-2006, 01:55 PM
man thats what I am talking about.
Old 03-25-2006, 02:02 PM
TSX420J's Avatar
no no no dont get it wrong im just saying its funny im not trying to flame anyone as i said i also say investment as well..
Old 03-25-2006, 03:00 PM
shitbox's Avatar
too bad the brembo blanks are not rust-proof.. they're cheap and it's brembo!!
any rotors dont get rust easily? or any rust-proof ones?
Old 03-25-2006, 05:30 PM
Haha, it's ok, just trying to clarifying my meaning to everyone else...that way, by saying investments, i will make myself feel better when i spend the money
Old 03-25-2006, 09:10 PM
Drives With Hands
rmpage's Avatar
Brembo rotors aren't "cheap", rust or not, appearance has nothing to do with rotor performance. If you want the non-swept area rust-proofed then get some Rotora, Stoptech or Racingbrake rotors. Racingbrake in particular are awesome.
Just don't get them drilled unless you want to be knee-deep in ricer territory.
Quick Reply: Rotors Poll: Racing Brake, Powerslot, Rotora, or Brembo Blank
