questions about tie and sway bars
I was just looking through some bars and had few questions.
whats the size of the stock front sway bar?
I was also looking into strut bars, they do tighten the chassis but wouldnt they also increase understeer? since they're stiffening up the front part of the chassis?
Top notch 6MT
Stabilizer Bars Front: 25.4mm
Stabilizer Bars Rear: 15mm (skinny!!!)
I think strut bars (those mounted at the top of suspension points under the hood?) would increase understeer, but don't quote me on it... experts, please chime in
Photography Nerd
No, the strut bars don't increase understeer. They simply provide a more rigid base for your suspension to work from. An increased diameter front swaybar will cause more understeer though.
Top notch 6MT
So what changes in handling can be expected/felt by having a more rigid base for the suspension to work from? That is, if one just change the strut bar (TSX has a stock one, right?) up front and not changing the sway/stabilizer bar.
Photography Nerd
Originally Posted by 05_TSX_GP
Thanks for correcting my wrong assumption ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
The towers move around a fair amount as some people have found out when they go to install the strut bar. If you have the car jacked up, the towers will lean outwards because they are unloaded. If you have the car on the ground, they'll lean inwards because of the pressure exerted on them. If the bar doesn't fit well when the car is on the ground, simply jacking the car up will likely bring the bolts back into alignment.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
