Port and Polish Links, anybody done this?
Polar Chicken
Anybody done this yet, I have found a few shops that do it in CA but am not sure what the gains would be in a TSX, I am guessing around 10-12 max:
JG Engine Dynamics:
Redline series All motor race / street / mild turbo
JGH 3001
Port work Redline series full port and polished 500.00 $
Intake valve guides tapered included in port work
Exhaust valve guides Tapered down included in port work
Valve spring retainers T 7075 Aircraft grade aluminum 90.00 $ max rpm 9500
Valve springs JG single 110.00 $ max lift 12.5mm
Valve job Full radius intake and 3 angle exhaust 150.00 $
Intake valves Swirl polished 40.00 $
Exhaust valves Swirl polished 40.00 $
Valve seals New 20.00 $
Head surface Milled or surface included in valve job
Chambers Polished included in port work
Cleaning Hot tanked 20.00 $
Total 970.00 $
ImportBuilders:
IB Spec head porting
Very advanced Honda heads. From 280-320 CFM. Flow charts available for an additional $100.
$875
DPR Racing:
Street/Strip Port and Polish and Competition Valve Job
This includes porting intake and exhaust bowls and short side radius
Match intake and exhaust 36 mm into ports
Competition mult-angle valve job
Hand lapped & vacuum tested valve seats
Lap deck and gasket surfaces
Deburr, clean, and reassemble
Starting at $750 (Milling $60)
STAGE IV
Competition Port & Polish
Competition multi-angle valve job
Set springs to customers specs
Polish Combustion Chambers
Back-Cut Valves
Radiused Blend Seats
Starting at $1050.00 USD (Milling $60)
JG Engine Dynamics:
JGH 3001
Total 970.00 $
ImportBuilders:
$875
DPR Racing:
STAGE IV
Back-Cut Valves
Photography Nerd
IMO the money could be better spent elsewhere. You're not going to get 10hp on an otherwise stock head with just a port and polish. 3hp would be more realistic.
Photography Nerd
I've been reading a few posts over at crsx and they all agree it's completely pointless. There's just not enough airflow through the engine to make it worthwhile. If you did an aggressive turbo setup then it might make sense.
So nobody has done this yet? Had a buddy with a '90 CRX that did it and picked up some good gains from it. I thought we might be able to do the same. Guess not.
Who wants to be the first thousand dollar test monkey?
Originally Posted by Zasker1
cam does no good without a new ecu.
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
InFaMouSLink
10-30-2015 09:43 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
