Turbo charge my TSX
NBP 08 TL Type S / TSX
Turbo charge my TSX
I don't know much about cars besides the basics and I am looking to Turbo charge my TSX. I don't know what I need to do it and money isn't a problem. I'm not looking to put CRAZY boost into it, but I want it to be significantly faster. Can someone let me know what parts, modifications, or at least the steps I would need to take to do so. I would really appreciate any info.
Welcome to the boards! As for turbo charging our tsx, there's useful information all over the place here. To start, use the "search" feature. It should help answer many of your questions.
jmcm3 (07-17-2023)
Photography Nerd
Since money is no problem, you won't have any problem. Money makes problems go away.
Regular TSX owners have big problems adding a turbo to their cars because of a lack of engine management options. Try a search to see what issues they run into and see if your budget really is big enough to say "money isn't a problem".
mrgold35
The is always supercharging for $4400+labor from comptech (about 260-270hp and 200-210 tq at the crank). A lot of members went this route and were very satisfied with the results from this proven aftermarket upgrade.
http://www.comptechusa.com/store/page5.html
Alright, since intalling a turbo requires a lot of engine management, what would be the easiest way to add some HP to my car without having to worry that I might be hurting my engine?
other mods to consider:
Header
Hondata Reflash
Exhaust
Lighter Wheels/Tires
Smaller Wheels/tires
UR Pulleys
Time to Climb
seriously though, if money isn't an option - forget about turbo because it's too many headaches and ditch the s/c because you can have more hp/tq with MR. HEELTOE'S HYTECH SETUP! very rare, incredible build quality, and remain naturally aspirated as honda's were intended. check this thread out:
https://acurazine.com/forums/sponsored-sales-group-buys-10/hytech-exhaust-engine-products-tsx-available-heeltoe-366315/
Originally Posted by tsx 2 nv
if money is not a problem.....why do you own a tsx?
Cybac (05-21-2020)
Cybac (05-21-2020)
Received 3,656 Likes
meh nooobs search
Go turbo. Trust me. Supercharged is okay, but you'll never think the same way again after you throw 8-10 psi at your car and see 400+ whp. K-series are amazing with boost. Since $ is no object, there are plenty of reputable engine builders out there that could build a bulletproof engine for you, and any good performance shop should be able to install everything and tune it properly. However, your stock internal motor will handle 8-10 psi no problem, if it's tuned well.
As far as engine management goes, KPro is what you want for a boosted K-series engine. Not sure if AEM offers EMS for our cars yet? I'm sure they do, but not 100% sure. A nice setup would be the block from your engine (k24a2), head from a k20a (JDM Integra-R) or k20a2 (USDM RSX-S), and tranny from either the Integra-R or RSX-S. k24 block has oil squirters, more counterweighted crank, plus you have added displacement, so it's really the best block for big power. k20a/a2 heads are the most free-flowing, however...interestingly enough...your engine (k24a2) has the most aggressive cams. You'll also have to do some changing around of some things such as oil pump, water pump, etc. if you go the k24/k20 route. Throw in a good clutch setup, maybe some better axles, and something like a GT35/40R turbo, and you'll have a pretty potent TSX
But yeah, a search will, I'm sure, yield you more info. I'm new on here and haven't used search yet, but this will get you started I guess.
GWEEDOspeedo
01-15-2016 10:39 PM
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
2006, 2007, acura, car, charge, charging, cost, ghjtyjt, hks, modification, performance, route, supercharge, tsx, turbo, turbocharge, turbocharging
