JTso's Custom Engine Torque Damper Setup (ETD)
#161
Driver/Detailer
Is it possible to mount the cusco-compatible bracket over the stock strut bar? On the AUDM Accord Euro, the mount points are used for a mini-strut bar that is connected to the firewall. Nonetheless, I still want to give the ETD a go.
#162
awesome stuff Jtso!! Looks like the cusco compatable one is a much simpler design that will fit tsx's universally with a lot of different strut bars (spoon, cusco, comptech etc.). Seriously impressed with what you've done.
aaronng, it looks like the bracket could possibly be mounted under the 'mini strut brace', but because the top of it isnt compeltely flat i doubt itd fit on top. If Jtso makes this available to us im just gonna take that little strut brace off... even if it requires an angle grinder lol
#163
#165
C'mon, man! Row yer own.
Yes, yes, I am anxiously awaiting the group-buy Acurazine extra-special price (for the stock-shock-brace model). My engine is torquing around in its cradle, I must have an ETD. Hook me up, JTso.
On a more serious note, does an ETD put more torque to the wheels (i.e., less energy spent moving the engine on its moorings = more energy to the wheels)? Or is that really negligible and it's mainly to prevent wheel hop, etc.?
#166
Driver/Detailer
Just checked my engine bay, you guys are right on that lip. So the option would be to put the minibrace on top. Hope that the bolt is long enough though. I see that the minibrace holds the A/C line and throttle cable in place on our RHD model.
#167
#168
The making of the mounting brackets is a proof of concept that it can be done. It would be ideal to have a shop to fabricate them and I put them together, or have a company like Ingalls to actually make and sell them.
First is to determine how many committed people that actually want them. Then find a place to make them and determine the cost and minimum order requirement. If the cost (including AZ fee if any) out weights the interest, then the other option is to make them by hands. The process would be slow, labor-intensive, and won't be cheap either.
Keep in mind that even the brackets can be made, I'm not selling the actual ETD unit. You can find them online or ebay. I'm only offering the mounting bracket solution. The quality of ETD unit and the included mounting hardware vary, but the sizing seems to be the same. I use stainless hex head bolts, nylon nuts, O-ring seals, and thick chrome spacers for the prototype setup.
#169
here's hoping that a manafacturer jumps on board and starts making these commercially... you've already done all the hard work, design/fitment wise, they'd be kinda dum not to
#170
Ingalls now has the 98-06 Accord on the list but release date is TBA. It might fit the TSX as well...
http://www.ingallseng.com/parts/ETD/93041.htm
#171
Driver/Detailer
The ingalls one would probably be designed around the stock strut bar or a popular TSX strutbar... I wonder if us with the Cusco bar will be SOL.
I'm still up for a JTso hand-crafted bracket.
#172
on the ingalls site they also say they need a tsx test vehicle for fitment etc.
the one for the 98-06 accord sounds like it may work... but like arronng said it probably wont be designed to work with the cusco strut bar.
So far what you've come up with JTso, is probably the closest thing to a universal application.
#177
Originally Posted by JTso
I thought about patent but have not done much research on it yet. Could you tell me a little about the process and cost?
I've been through the process before from within my business, so my perspective would be different than an individual. However, I would start by looking up a Patent Lawyer first. They'll file the paperwork and do it correctly.
#178
Port & Polish Everything
he'd obviously need to figure out if he can recover the investment in future returns.
#179
Originally Posted by outersquare
that typically costs a small fortune though, i recall starting around five figures or so for the whole process once you get a patent lawyer involved.
That is definitely the risk you take in going after a patent. I've learned that taking large calculated risks and working smart equals big rewards.
That's how I got my son!
#180
^haha
but if JTso takes out a patent, and ingalls decides the TSX market isnt worth making the ETD for it may not bother buying it, they could also come up with a different design.
I didnt realise taking out a patent costs so much.
#181
Photography Nerd
Just be first to market Johnny. No need to patent it since you'd never recover the costs. If you were designing a revolutionary engine mount or something that Honda would be interested in, it might be another story. This sort of thing would be hard to get a patent on as well since there is plenty of "prior art" in making brakets and engine torque dampers.
The one thing to remember about patents is you can only defend your patent if you have enough money to do so. It'll give you the upper hand in a court case, but you still need to take it upon yourself to sue someone who infringes upon your patent.
Just get to market first and be the number one name in engine torque dampers for the TSX. It won't be worth Ingalls time to go against you in this limited market segment.
#182
Received 3,789 Likes
#184
Thanks guys for all the suggestions. I probably can't afford to pursue a patent at this point. I'm more interested in making the product available to our members.
The brackets are just simply something to mount the ETD. We should pay more attention to the ETD unit. It would be great to have an actual gas/fluid filled shock unit instead of bushings. Does anyone know of any mini shock absorbers?
#185
A DiRTBAG decal on my
What about the ones used for the trunk shocks? Not sure of the sizing of those
#186
#187
well considering the rubber/polyurethane ETD unit's are working a treat, why bother going to something that is gas/fluid filled? It'd probably bump up the price considerably aswell
#188
I just took a quick look around and, at least in terms of bike rear shocks, they're air/oil but they're expensive. Seems like the better bet might be to contact NRG and see it they're interested in selling a gross.
#191
Someone stole "My Garage"
I think you are right. The poly bushings will probably last forever.
#193
Originally Posted by jiggaman
so when can we buy these mounts JTSO?
#194
Bye TSX, hello domestic?
#195
Originally Posted by peter_bigblock
yeah, you keep tempting us with pictures of them and descriptions of how well they work and how great it is for you that you fabricate and weld so professionally. what about the rest of us? more to the point, what about me? i'm clearly too lazy and cheap to learn to weld and invest in a bandsaw and all that, yet i need those brackets. can you feel my pain?!
#197
Driver/Detailer
Since JTso has so little time, I guess that's why he makes full use of what little free time he has and comes up with such wonderful creations. Unlike us, just 8 hours of work, 30 minutes commute and all the remaining time for those who are not married.
#198
I'd like to make the brackets available if I have the time. I started at work this morning at 7:00am PST and I'm still at work 12 hours later typing this post. 2 hours of commute time, 5 hours of sleep, 1 hour lunch, 1 hour dinner and 2 hours spending with family = 1 hour left to myself. How should I spend that 1 hour? Btw, sometimes I work 7 days a week including travel to Canada. I may seem very available online because I have access to computer at work. Please be patient, things will slowly happen.
#199
#200
