JTso's Custom Engine Torque Damper Setup (ETD)
#51
Driver/Detailer
Welders are truly artists. I knew one who had to get certified for welding the hull of a ship. it's not just getting the metal to stay in place. The welds have to form part of the seal as well and has to be airtight.
#52
Thanks guys. I took a welding course 3 times, a total of 180 hours to learn how to do the basic techniques with gas (obsolete now) and arc welding (I have a TIG). My instructor is very critical as he is also one of those certification inspectors. The school has programs to refresh seasoned welders prior to the examine as well as new people trying to get into the business. I was the only one in class that did it as a hobby and my goal is to create things that are not available or to improve an existing design. Therefore, I'm actually open to ideas of what people would like to see for the TSX.
#54
Originally Posted by moda_way
^^ Now for the bigger question, are you willing to sell these things?
#55
Driver/Detailer
Originally Posted by JTso
Sure, of course. But I need to find a place that can duplicate the brackets as it's the most time consuming process. I might be able to hand make a few while searching for the right shop. I also need to test the strength of the design to make sure it will hold up over time. We all know how critical TSXers are.
#58
ETD video
Here are some clips of the engine movement with and without the ETD. The ETD is set to a softer setting at 14mm (15mm = softest, 10mm = firmest). The engine is reved to 4500 rpm.
Please right-click the links and select "save target as..."
With ETD
Without ETD (ETD disconnected at engine mount bracket)
With ETD
#60
I just got done looking at the video and was thinking if you were to make another
bracket and damper for the left side of the engine you would have even less movement and even pressure on both sides. It would also relieve a lot of the stress on the brackets. Just a thought...
#62
If there is a place to duplicate all the bracket pieces, I can weld them up in no time.
I would like to go ahead and volunteer my car for the Cusco ETD as well That is if you can't find someone closer to you for it.
#63
Received 3,858 Likes
#65
Originally Posted by curls
So would this mod be similar to the 'ol "Energy Suspension engine mount bushing inserts" for most non-hydraulic mounted motors? With the exception that <somehow> no vibrations are transferred back to the cabin at idle?
#66
Someone stole "My Garage"
Originally Posted by jpt
The "somehow" is that it's a gas shock, not a piece of rubber -- most of the energy from the engine vibration therefore is lost on compressing and expanding the gas in the shock absorber rather than being transferred to your chassis like with a firm engine mount insert.
And the other similarity/benefit of the gas shock over the ES bushings, in terms of wheel hop, is that the gas shock can't be compressed quickly at all to any large degree, thus keeping the engine stabilized. Kinda like the best of both worlds -- enough "play" to keep vibrations from being transferred to the cabin, but not compressable "quick" enough to allow engine torque to make the wheels hop.
JTso - Stock strut bar compatibility with the current version?
#67
Gotcha, thanks!
The v2 bracket should fit the stock strut bar as it fits the same way as the Comptech bar.
Some quick feedback...
1. The v2 shock tower bracket is still holding up fine. However, I did notice the very end of the bracket lifted up approx. 1mm. It's not twisted like v1, just lifted up evenly. I think the extra brace did help. This 4 cylinder engine does have some torque.
2. The steel brackets seem to transmit slightly more vibrations than the aluminum brackets. I had to back off the setting slightly to the softer side to have a nice balance between vibration with AC on and wheel hops.
3. The softer setting still works very nicely to control wheel hops during launches, but it didn't eliminate it like the firmer setting. I can feel it's trying to hop but never really able to. The tires then chirps instead of hops.
4. I have reinstalled my Cusco type 2 bottom brace. No more banging problem from the flex pipe.
#68
Nice job! I have seen it on Ebay and thought it wasn't worth to purchase it. But I am glad to see that you bought and installed it. It seems to me is worth to buy one, Thanks JTso.
#70
Originally Posted by jiggaman
i wonder if this mod would reduce vibrations from comptech header install, BTW nice job JTSO!!!
#71
I spend 2 much time here
what vibration are you talking about as I am looking to buy one as soon as tomorrow afternoon.
#72
#75
Wow. I skip out reading around this place for a few days and look what happens, brand new innovation! Amazing!
One of the things I have noticed in my car is the distinct increase in cabin vibration I've noticed over the 6 months I've owned it. I don't know if its a function of summer and the A/C all the time but it seems to be getting worse, so bad that I've considered taking it to get looked at.
If this really does what it sounds like (eliminate cabin vibration, pedal / wheel vibration especially) I'd be glad to help bankroll a few of these into production.
Anyone know where ingalls is on their product?
#78
I'm now brainstorming another design to address the infamous issue of "vibration". If you look at the existing mounting design and all other designs out there, they all use a metal-to-metal solid mount which can potentially cause unwanted vibration. So, I'm thinking about changing the mounting design with a poly bushing with a metal sleeve in the center where the mounting bolt would go through. This effectively becomes a real shock absorber mounting design that further reduces vibration and still provides effective ETD function. I'm thinking some small end-link donut bushings might work...
#79
Got Milk???
That's exactly what I've been feeling, actually from the beginning when I got my car, the steering wheel vibrates a bit now it's vibrating a lot, especially when the car is warming up. I've thought this is normal, but correct me if I'm wrong.
KC
#80
Got Phó?
