J's Racing CL7 Header
#41
Question regarding the J's racing 70RR, so this exhuast will bolt up to the J's CL7 header and thus eliminate the cat and the piping is from the header all the way back correct. If this is the case other than being illegal performance is what you would expect no restriction, as straight through as it can be and with the ECU reflash you can expect power throughout the rev range. I am seeing atleast 20+whp there. With the 70mm piping of the J's if you plan for future upgrade like say cams, S/C, etcc.. this exhaust would be best suited for.
#42
Originally Posted by aaronng
This J's racing one DOESN'T fit the CL7 cat. They use their own flange pattern and angle, hence you need the J's racing testpipe.
You can always buy a highflow cat (or use your existing one) and get the exhaust shop to weld the compatible flanges (and piping if required) to match the length and angle of the J's racing test pipe.
lanechanger
10-13-2015 10:56 AM
