JDM Headlights Adjustment
I had installed on JDM headlight on my Tsx and never seen that adjust the headlight. I had no problem installed it and very easy. But you have to be careful removing the HID kit for low beam and other bulbs remove too.
Received 3,858 Likes
Originally Posted by huckleberry
OK so you guys never bother to make them US-spec-compliant....
But back to my question:
Is that the way to make them US-spec-compliant ?
thx
thx
send me a link to JDM??
thx
thx
There is no real way to do it. Each of the lights has the pattern in it (high on the left low on the right for JDM). You can test what I'm saying out by covering up one light, you will still see the pattern. People always think that one light is just aimed higher then the other but its an actual metal bracket inside the light that makes the pattern. When you install the lights take a look inside and you will see it.
There was someone abroad, I will look for the PM and find out who. That disassembled the entire light, custom fabed brackets that went the other way, and put it all back together again, but I don't know why you would go through all that trouble, plus the risk of getting moisture in the headlight.
No one really notices. The rise is so minute that I doubt any one with the JDM lights has ever been flashed... I havent.
Originally Posted by JTso
Take the projectors from the US spec housing and transfer them to the JDM housing. The beam pattern is within the projector.
just dont touch the bulb at all. if you get the oils from your hands on there bulb as soon as they get power they will fry. also I have never been flashed since getting my JDM headlights. maybe the people in my area are used to it now.
Originally Posted by TSX.Fury
No...
yeah I know what you talking about the metal shield in the projector.
one thing I will tell you:
Apparently the projector is specifically designed to be impossible to be taken out the back.
I played around for a couple of hours trying to get it out the gentle way,
in the end I had to give it hell and pull it out by force.
ah I see thanks !
hehe I actually pulled out the projector from a spare headlight the other day
Bye TSX, hello domestic?
Originally Posted by pizzaman555
How did you get that projector out. It must of been allot of hard pulling right.
Originally Posted by xizor
I dremeled the housing when I took out a projector from a busted headlight, its either that or unglue the whole thing and seperate the housing
I pull it out the hard way yes, metal > plastc, so just a microscopic little piece of plastic chipped off the opening edge.
what you mean "dremeled" ? how ?
Hmm... did those red fasteners break off from the housing? They look like drywall anchors. Are the screws permanently attached to those fasteners?
just pay no attention to them
I put them there to keep the screws from sliding out.
So the projector should come out of the housing after removing the screws? You mentioned that it was difficult to come out...
that opening looks big enough but like i said it seems Stanley on purpose made it 1% too small
Originally Posted by mav3556
So where did you guys get your JDM housings installed at ?? I got my done at a Acura Dealership
have any of you who have the JDM EURO R headlight housing, had any problems with it?? Such as fogging up or condemsation?
2005, 2006, acura, adjust, adjustment, allignment, headlight, headlights, jdm, level, mdx, power, projector, shield, tsx
