intake with better Throttle Response
as all we know DBW put down fun driving often....
does icebox gives better response? how about injen and typhoon?
if any aftermarket intake gives even slight better response, i am ordering it now... if someone gives me good link to purchase, u will be blessed....
Comptech Icebox = better low to mid end response, not as much top end gain
Injen/Typhoon CAI = loss of power in the low end but gain more at the top end
If you're after better throttle response, then the Icebox is the one to get.
Someone stole "My Garage"
If you're really after instant-response from the go-pedal, any short-ram system will suit your fancy. But then again, the top end gains are usually pretty negligable because they aren't drawing in cool air.
I have an Injen and love it. Coupled with the DC Sports header, it provides plenty of fun over a stock TSX, in terms of responsiveness.
I have the CT Icebox and I think it improved throttle response. The Icebox air box lid is larger volume so there is more already-filtered air available when you mash the throttle.
Originally Posted by dolparism
does injen make even worse response?
Originally Posted by jlukja
BTW, to me
throttle response =/= low rpm power
BTW, to me
Originally Posted by CarbonGray Earl
completely agree. People tend to get it mixed up around here.
Response = what JTso said -- A good throttle response is how quickly and smoothly the engine reacts to throttle inputs.
The Injen and most intakes allow better response (larger diameter and more efficiently-flowing tubing = more air available to be sucked into the engine in a hurry).
sean...do u have MT or AT?
so you don't feel power loss during normal driving?
CAI or SR.....??
In thinking that throttle response might be helped by having more air available, I used the '06 intake tube, the part between the airbox and the engine, on my '05. It's a small increase, but it's also not expensive -- it's easy to try and easy on the budget. Hard to say how much it helped, because it's such a small improvement and it's all subjective.
I looked at doing that as well. I think there is a small difference in the inside diameter of that intake tube. Some time ago I sat down and figured out that the difference would account for something like 10% more airflow.
I would agree though, just calculated it based on the diameter and length difference (assuming lengths are the same) and go from there. Hey, 10% is better than 0%
I be an injuneer.
Nice to see you post again, I was afraid you were crushed by your CT header.
rcs86
08-02-2016 06:52 PM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
