Injen SP Cold Air Intake System Acura TSX with MR Technology-Converts to Short Ram
Originally Posted by Reach
I don't believe there's an MR for the TSX. That intake looks more restrictive than the RD anyway.
There's no way that thing fits on a TSX.
T.DoT P.I.M.P. lol
1 Post
O sHit~ This is the 1431???? Someone on the "other forum" has sent an e-mail to Injen, their reply was another 8-10 wHP on dyno than the 1430 Injen CAI that we are using now. Hope it goes to production sooon.
Rep'n Taxbrain.com
Found some more info on the Injen website about the MR technology. Basically, they are saying that with most intakes, the Air/Fuel ratio will become very lean when running it with the standard ECU. There new MR intakes are suppose to be tuned for our specific cars so that the A/F ratio is more ideal.
This sounds like a good idea but I would think if you have Hondata then it would not give the same results since you're tuning would probably be different from the ECU that Injen used to tune their intake. I'm not 100% sure about this, so someone please correct me if I'm wrong.
Here are some comparision dynos. This is not a TSX, it's a Miata I think. They are just using this as an example.
http://www.injen.com/MRtechnology/MRtechnology.html
Team Hybrid
Originally Posted by indytsx1
Hey guys, I just wrote Injen. It appears that part number SP1431 is this intake with the MR technology which is tuned for each vehicles fuel/air ratio. It is listed on a few of Injen approved on-line vendors. However, it is not even on Injen's website?????If it is for our car I requested the Dyno results so we can all compare the RD1430 and this "new" intake.
so what indytsx1 said i can sure thats true =)
good point tsx536, I have a stock AT and want to do some mods, Hondata, Intake, etc. I will contact Hondata to see what they think. I hate to spend the extra
if the RD1430 is the best.
I wrote him back with a question in regards to having the HONDATA reflash and if it messed with the performance since the MR Injen was designed for the factory air/fuel ratio. I'm a newbie but don't think the HONDATA reflash messes with the air/fuel ratio. I thought it only changes the VTEC "kick in" point. Well, if this MR Injen is the replacement for our TSX then I'm hoping that means the RD1430 will be on SALE soon
Below is the response back from Injen
The HONDATA reflash actually remaps the ECU to get the most performance out of your engine. Because we tune the intake to more closely follow the factory A/F ratio it will help that even more.
Technical Support
Injen Technology Co., Ltd
Technical Support
Originally Posted by vasu
is the only advantage to running this in SRI mode for the easier installation, or are there other reasons too?
-vasu
-vasu
i) Easier to replace the filter when needed
ii) No need to worry about sucking in the water
Technical Support
Technical Support
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
hey guys i found this surfing it seems to be the same a rd1430 but it calls it the sp1431 ??? misprint? http://www.cardomain.com/shoplist~t~...ke%2520Systems
What's weird is if you look at their dyno graphs, the baseline on the chart with their "non mr technology intake" is jagged, but the baseline on the dyno graph with the "mr technology intake" is smooth? See for yourself: http://www.injen.com/MRtechnology/MRtechnology.html
Something's not right...
what advantages/disadvantages (other than installination and maintaince) does SRI and CAI have, i know CAI may suck up water if you drive in the ocean and hydrolock the engine, but how much advantage does SRI have over stock and also with the CAI?
I am going to buy a CAI soon as i do the suspension this month and am still undecided so here is all the info Ive collected so far...
fujita cai
k&n cai
injen
injen with mr technology
injen without mr technology
Did anyone find out if using the mr version with reflash would have a negative affect as to using the regular injen cai with reflash????
looking at the dynos I see that the one with mr tech has a lot more gains in the 3200 and on and the regular one only has a lot of gains below 3200 but really doesnt have any good gains after that....
fujita cai
k&n cai
![](http://www.kandn.com/dynocharts/69-0025.jpg)
injen
![](http://www.injen.com/webpages/testing/original_files/rd1430.gif)
![](http://www.injen.com/SP1431/chart_2_bg.jpg)
![](http://www.injen.com/SP1431/chart_1_bg.jpg)
Does any one know if the injen HYDRO SHIELD (a pre filter for the filter) causes LOSS of HP? biggest reason why is probobly much less serface area. what would be more HP LOSS BYPASS VALVE or hydro shield? would u get more HP gains with SR and NO H. Shield or CA with H.SHIELD? and last of all for TOP END power wouldnt a SR jenerate MORE power than A LONGER RUNNING CA tube, ESPESSIALY with the new MR CA tube being a lot thinner atachment?
some things I read: for every 10 degrees of cooler denser air u gain average 1% HP so CA is approx 24 degrees cooler
