Ingalls ETD should be available to anyone now
#322
T.DoT P.I.M.P. lol
1 Post
Originally Posted by TSX 3Pedal
Where are you guys checking to see if you received your invoice?
I checked my email that's linked to my PayPal, but nothing yet.
Same, no invoice yet.
#326
Mine is in a sort facility 15 miles away but it says delivery tomorrow Want!
To those who have not gotten the invoice yet, Excelerate said he would ship them out in roughly the order of payment received, so please be patient!
#328
#330
Rep'n Taxbrain.com
^^ Yep, I have my invoice too! Mine won't be here until next Monday though. I'm going to be in NYC and Baltimore during the next two weeks, so I probably won't install it for awhile. It's all good, cuz I'll be vacationing!
#333
where is my garage?!
1 Post
just received
got it at work. some crude pics w/ my camera phone. too bad i'm going to be away this weekend. no install
stiffy itself
bracket w/ sweet ingalls diecut, another bracket, and hardware
*edit* cleaned by reach
stiffy itself
#336
#339
Rep'n Taxbrain.com
Originally Posted by CGTSX2004
You gonna come down to DC from Baltimore or are you just staying up in the slums?
Has anyone installed their ETD yet? I'd love to hear some initial impressions.
#340
CL9 ABP
So i installed mine today with mephisrheins.
We needed to jack up the car and remove my nuespeed strut bar.
Then remove the third nut that is part of the strut suspension.
We then removed the two bolts on each side to loosen the stock strut bar that we need to do, slide the bracket under the stock strut bar.
We had to drop the whole suspension even maybe take off the wheel to help us but in our case we drop the strut completely out of the holes to slide the bracket.
Then line up the bracket and put back the strut on. (we lowered the car so it would fit back in the holes nicely.)
Then tighten all the bolts back put on nuespeed bar back on.
Next engine bracket we just remove the two bolts using a breaker bar.
The rest was simple enough although i have 2 nuts left over and one bolt??????????????????????????????
#341
Originally Posted by Excelerate
If you don't see your invoice in your inbox check your Spam folder. Sometimes it will go there.
Thank you to all and you're welcome. I busted my behind to get all those packages out on Monday.
Alright - to anyone who has already received VIA UPS...
Did you need to sign for the package? Or did they leave it, I might not be home when it comes and I need to know whether or not to tell my neighbor to sign for it.
#345
only had time to get the chasis mount on..will have to finish it up tomorrow. anyone have any recommended adjustments for the stiffy??
Also, does anyone know what I should torque the 3 14mm nuts that secure the strut to the strut tower to?
#346
Use all 3 Pedals at once
#347
E92
Yeah, I'm planning to go down to DC and all around. I'll be free Sep 4th and 5th, so if any of you guys happen to be around then let me know! First time I've been to the East coast in a long time so I'm pretty excited!
#351
Alright, I've installed mine and I have a few helpful hints from the instructions, but first, my opinions.
I FREAKIN love it. Remember, I have the Fidanza lightweight flywheel and ACT 6 puck clutch. This thing makes the wheels hook up so much better and really smooths out the motor engaging. I didn't even know that what I was feeling was the motor until it disappeared with this. This is a must have if you've done mild to significant mods increasing HP and torque. Let's sum it this way, the motor is much smoother in transition from load to unload.
Okay, now to the hints. I would've like a few more pics on the instructions, but they were sufficient. To get the chasis plate under the strut bar, requires you to physically push down on the wheel after you've taken all of the bolts of the top of the shock mount. Once off, I used my foot to push the wheel down (mind you, it is on jack stands... a must) while at the same time, I used a pry bar DELICATELY to push up on the strut bar on the backside of the bar.
Next hint, use a box end wrench to hold the bolt for mounting the stiffy to the chassis plate. Just drop the nut into the boxed end (I think it is a 15mm wrench) and that way you can be careful around your ABS unit. You won't get your fingers in there nicely. Come in from 90 perpendicular to the stiffy on the left of it. There is a perfect space.
Finaly hint, don't tightly secure the stiffy to the chassis plate until you've lengthened the end to match up with the engine mount plate. You probably will have to lengthen the stiffy end by loosening the nut on it (on the end that mounts to the engine side) to reach the bolt hole of the plate. By not tightening it down, you can move the stiffy over to undo the bolt and lengthen the end with enough room.
I didn't take pictures because I'm sure plenty of you will. Love this mod and it adds some bling to the engine bay while being completely functional. It has tamed the beast. Oh, last comment... I haven't gotten any vibration in the passenger compartment yet. Of course, I'm on the default setting for the stiffy too. I don't have a 27mm wrench, only a single 1" and that won't do me any good unless I have another wrench to move the adjustment nut.
EDIT:
I had 1 additional bolt, washer and rubber washer (the same one you'd use to mount the stiffy to the engine side). Did everyone else?
EDIT:
#358
I Quit
Originally Posted by moda_way
I certainly wouldn't call this a difficult install at all.
#360
Oh, thats a good question.
Your torque converter would take up most of the engine torque that the manual guys have to deal with themselves, so - I would say no IMO.
