ingalls ETD help
ingalls ETD help
hey guys i just installed my Ingalls ETD on my 07 TSX
fit is fine, only issue is a headliner scratch on the hood.
Anyway to fix the headliner issue?
Also theres in idle when the AC is on the car vibrates like crazy anyway to reduce this or is that normal?
I put a rubber 0 ring in there that came with it
thanks
thanks
C'mon, man! Row yer own.
thanks
thanks
Let me help you!
It's a known issue. If you do a search for it, you'll see what people have done with their units. Some people just cut into their headliner to give it clearance. Others will grind/dremel the unit.
Alot of people complained when it first came out, and Ingall said that no two TSX's are alike, so you'll have to modify the unit for your particular case.
As for the A/C, that's normal. By installing the unit, engine vibrations will be sent into the cabin.
anyway to reduce it? or anyway to grind down the bracket?
As for the vibration, you can experiment with different o-rings from Home Depot or the auto parts store. But part of the idea is you're more directly connecting the engine to the chassis and you're going to get an increase in vibration as a result.
Driver/Detailer
With the ETD, added vibrations from the AC is normal.
Vibrations are normal. just pretend u drive a cammed big block.
My TC was the worst when i had it. It vibrated hard enough my windshield wipers would vibrate haha
here is what im talking about see how it twists to the right
http://img179.imageshack.us/img179/8397/image017hs2.jpg
can anyone clear it up for me thanks
lanechanger
10-13-2015 10:56 AM
