Increasing horse power for dummies
Master Graphic Artist
For those that don't know much about cars, other than turbocharge = faster car, on this forum (like myself) here are several ways you can increase horsepower to your TSX. Just making a point to what and why each modification will increase horse power. This will save time for each individual search.
howstuffworks.com
These compromises often give you lots of room for improvement in terms of performance! There are many different ways to create more horsepower from a stock engine. Here are several examples (generally in order from least to most difficult/expensive):
Change your computer chip - sometimes, but certainly not always, you can change a car's performance by changing the ROM chip in the engine control unit (ECU). You usually buy these chips from aftermarket performance dealers. It is valuable to read an independent review of the chip you are contemplating, because some chips are all hype and no performance.
Let air come in more easily (Intake Tuning ) - As a piston moves down in the intake stroke, air resistance can rob power from the engine. Some newer cars are using polished intake manifolds to eliminate air resistance there. Bigger air filters and reduced intake piping can also improve air flow.
Let exhaust exit more easily - If air resistance or back-pressure makes it hard for exhaust to exit a cylinder, it robs the engine of power. If the exhaust pipe is too small or the muffler has a lot of air resistance then this can cause back-pressure. High-performance exhaust systems use headers, big tail pipes and free-flowing mufflers to eliminate back-pressure in the exhaust system.
Change the heads and cams -- Many stock engines have one intake valve and one exhaust valve. Buying a new head that has four valves per cylinder will dramatically improve airflow in and out of the engine and this can improve power. Using performance cams can also make a big difference.
Stuff more into each cylinder - If you can cram more air (and therefore fuel) into a cylinder of a given size, you can get more power from the cylinder (in the same way that you would by increasing the size of the cylinder). Turbo chargers and super chargers pressurize the incoming air to effectively cram more air into a cylinder. Many manufacturers make aftermarket turbos and super chargers for many different cars.
Cool the incoming air - Compressing air raises its temperature. You would like to have the coolest air possible in the cylinder because the hotter the air is the less it will expand when combustion takes place. Therefore many turbo charged and super charged cars have an intercooler. An intercooler is a special radiator through which the compressed air passes to cool it off before it enters the cylinder.
Make everything lighter - Lightweight parts help the engine perform better. Each time a piston changes direction it uses up energy to stop the travel in one direction and start it in another. The lighter the piston, the less energy it takes. Lighter parts also allow the engine to rev faster, giving it more horsepower.
Increase the compression ratio - Higher compression ratios produce more power, up to a point. The more you compress the air/fuel mixture, however, the more likely it is to spontaneously burst into flame (prior to the spark plug igniting it). Higher octane gasolines prevent this sort of early combustion. That is why high-performance cars generally need high octane gasoline - their engines are using higher compression ratios to get more power.
Increase displacement - More displacement means more power because you can burn more gas during each revolution of the engine. You can increase displacement by making the cylinders bigger.
howstuffworks.com
While this information covers the basics, it is still important to understand that an engine is an intricate balance of mechanical parts and tuning is a little more complex than the basic steps mentioned in the above article. Also, different tuning methods produce different results (i.e. trade-off between hp and tq) so those are all things that need to be considered.
Originally Posted by iamhomin
You love howstuffworks.com don't you? ![Jesus LOL](https://acurazine.com/forums/images/smilies/jesuslol.gif)
iamhomin, who has read this article a while ago.
![Clap](https://acurazine.com/forums/images/smilies/clap.gif)
Acura604
20
08-05-2017 12:55 AM
