hid headlight question
i want to upgrade my oem hid bulbs to "philips 6000K ultinon", so i guess the product i should be looking for will be "PHILIPS 6000K Ultinon D2S bulbs"?
there is only one kind of bulb under this name right? (i mean...there's no H1, H2...etc, as long as it says "D2S", then it's good?)
the reason i'm asking this is because i found a set of this on ebay selling for $200 here, on the website it says the bulb type is T-9 which I've never heard of it, so i am kinda worried there are different types of bulbs all under the same name "philips 6000K ultinon".
also, does anyone know where i can get this in good price? is 200 a pretty good deal?
i want to change oem hid bulbs too, so any D2S bulb will work for TSX? so basically D2S hid bulb works for all the cars out there? (seems each individual brand only makes one kind of D2S bulbs for direct replacement for the oem hid bulbs)...is that right?
thanks
thanks
I Quit
D2S and D2R are reference to HID bulbs, your high beams ARE NOT HID. So the ONLY HID bulb you have is the low beams which is D2S. Your fogs and high beams are halogens and I believe the fogs are H11 and the high beams I'm not sure....
iVTEC no koe
Originally Posted by ItsHersTL
Im going to throw the total noob question out there & ask what years came with HIDs & if so, what bulbs? D2S for the Low beams & D2H for Highs 7 Fogs?
As copied from Sylvania site for the TSX:
Low beam headlamp
HID-D2S
High beam headlamp
H1-55W
Parking light
168
Front turn signal
7440
Rear turn signal
7440
Tail light
7443
Stop light
7443
High mount stop light
7440
Fog/Driving light
H11-55W
License plate
168
Back up light
7440
Front sidemarker
168
Rear sidemarker
168
Map light
DE3175
Dome light
DE3175
Trunk/Cargo area
168
^ That is GREAT info! So many questions get asked about "what kind of bulb goes where" in our cars now that light changing seems to be all the rage.
We really should have this info in the FAQ somewhere!
It should also be noted that a 168 bulb is identical to a 194 bulb (which is the more common nomenclature, at least for aftermarket parts), and the festoon bulbs in the TSX (map lights, rear dome light, etc) are 10x30mm.
Reach - what kind of headlight bulbs do you have in your car? I have the OEM and i'm looking for something a little bluer kind of like yours...i changed my fog lights to a bluish so i want everything to match...
boost owns
Originally Posted by TacoBellSauce
D2S is for projectors while D2R are for the regular housing HIDs right?
the last gen TLs used D2R also, right?
Guys, I'm using the stock D2S bulbs. The bluish glow in my housings is from bright white LEDs going through the jdm sidemarkers. Search for the 2006 jdm lights to see big pics of them and you'll get an idea.
boost owns
where did you get the cleared out headlights from or can i do it myself?
You can order JDM headlights from a number of places including our board vendors (Mr. Heeltoe?) although I think they're kind of hard to find/back-ordered.
Originally Posted by Audioserf
Reach has the 2006 JDM headlights; to my knowledge, he didn't clear them himself.
Originally Posted by jl1080
Quick question Reach, what kind of bulbs did you use for your fogs?
BoricuaTL
04-08-2016 01:08 PM
pistacio
09-26-2015 09:45 AM
