Hawk Ceramic Pads Install Question/Help !!!!!????
#41
Originally Posted by joerockt
My EBC's had the shims built in, so when I tried to use the OEM shims, the caliper wouldnt fit. So if you ran into the same situation, and you dont have squeaking, then I wouldnt worry about it
#42
Driver/Detailer
I have ceramics and reused the shims. The pads fit in, no more tighter than the OEM ones. You need to readjust the tabs on the shim because the ceramic pad is slightly taller.
mada51589
05-03-2022 08:54 PM
asahrts
09-04-2015 05:55 PM
