Givin it more Bottom End?
#41
Originally Posted by Alfie
I had UR pullies on my AV6 as well...and I never had that problem. Could've been a completely different problem that you were blaming on the pullies. It'll underdrive the AC a bit, but it shouldn't be hot as balls.
go with NST they do both underdrive and overdrive with the pulleys which helps even out any underdrive issues. they give a good explanation on what it does on their website at http://www.nonstoptuning.com/pKitHonTSX.htm, you will see on the left there is a definitions section and you can see what it exactly does.
#42
T.DoT P.I.M.P. lol
1 Post
Originally Posted by 1slicktL
if i was to get the pully would it make my a/c all retarted because i had the UR pully in my 04 accord and the ac was hot as balls when i am at a stand still...
j/k. I have the UR 3pcs pulleys installed on my car last year, good gain, and no problem with full A/C on. Most of the time I only turn on the A/C 2 out of 5 @ 20C cause higher (fan rate) than that it's too cold.
#43
MrHeeltoe
20
02-23-2023 01:54 PM
IBankMouse
06-13-2020 12:53 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
